Thread: Went to wire up the speedo...
Page 8 of 10 FirstFirst ... 45678910 LastLast
Showing results 141 to 160 of 195
  1. #141
    11-29-2009
    Chadds Ford, PA
    2,768
    WAHOOOOOOO i am happy for you guys. This is great news! John makes sure you write a tut up on it. I think this should be stickied? anyone agreed?
  2. #142
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Agreed!!!
  3. #143
    I think there is an easier way so this weekend i am going to investigate further to see if can use some of those existing wires in the engine that are no longer used. Im sure one of them is a switched 12v and ground and we should only have to run one wire if any.
  4. #144
    12-02-2008
    1,263
    Quote Originally Posted by Johnathansgalant View Post
    I would love to help out here but engine is back out of the car and wont start back til end of the month. But that would be awesome man...keep us posted. Finaly us 02-03 people have hope
  5. #145
    Thanks guys all your hard work made it super easy for me!!!! im in the process of finding my trans now!
    2002 5spd swapped
    under construction.....
  6. #146
    Ok so i was able to use a 12v and grnd from the original input output shaft sensor harnesss. I dont know which one yet but both of them have three pins and they are 12v 5v and grnd. You can use those for the power and ground and you will have to run the signal wire into the yellow black c 17. The harness i used has a black white / green / x and black wire. The black white is 12v and the solid black is grnd. The green is not used and is 5v.
  7. #147
    just a little update, I noticed that at high rpm, around 5500 my speedo stops working, and I'm wondering if anybody else has experience the same thing...
  8. #148
    06-13-2008
    Bronx, NY
    2,606
    Great good job. just on time for my 5 speed. x2 on the visual.
    SOHC Turbo
  9. #149
    08-15-2006
    Perth Amboy, NJ
    1,558
    doesn't happen with my speedo :/
    run1206's Rear Disc Tutorial
  10. #150
    hmm maybe I tapped into some wire that shuts something off at a certain rpm OR my new speed sensor is crapping out already :( I'll look into it hopefully lol
  11. #151
    10-18-2007
    Glen Burnie, MD
    1,314
    Guys I need a favor. I went to pick one up at the local dealer and there are 2 different ones between 00 and 05. There are serial numbers on the very top of the speed sensor. Can someone with a working speedo get that part # for me so i can get the right one? thanks lol
  12. #152
    10-18-2007
    Glen Burnie, MD
    1,314
    Someone help me out!!!
  13. #153
    speedo
    Hey guys sorry i thought the site was down and havent posted.. Check where you tapped the speedo power it should be a switched 12v from the large power wire on the c17 harness. IT should not cut out at all..
    Also i have used a speedo from an auto 01 galant, 03 manual eclipse and 02 eclipse and all have worked fine..
  14. #154
    Wow, I can't believe there is a definite solution to this dilemma. I was gonna use a cell phone app to see how fast I am going cause I was fed up with this speedo issue. Thanks for the contribution.
  15. #155
    I've installed the evo 8 ecu on my car, as well as the 5 speed swap. can I use the same wiring described on this thread to make the speedo work? or is it entirely different?
  16. #156
    its the same^^
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
  17. #157
    Thanks reiketsutsukigami, I'll give it a shot tomorrow.
  18. #158
    Simple and elegant solution with no pulling of wires anywhere when swapping 4G64 auto transmission to 5 spd along with a 3G or EVO ECU:
    As John stated, power and ground come off the stock output shaft sensor harness. Now wire your signal wire from the vehicle speed connector to the signal wire of the output sensor harness. You will use all three wires from the output shaft sensor harness. This is the little black 3 pin connector on your transmission that looks just like the plug for the cam sensor on an I4.
    Now simply cut (disconnect) wire 80 on Connector 41 (Yellow / Black : 22 gauge or so [ie: THIN]) from the automatic I4 harness at the ECU side and splice it into pin 86 on connector C-115 (3G ECU or EVO ECU).
    Tach works perfectly.
    Greg
    '01 Stratus R/T - 5spd, 92 3000GT VR4, 03 EVO VIII, 70 Opel GT
    Owner - Ultimate Car Style & Performance www.ucsperformance.com 240.271.0280
    2007 N.A.S.A National Champions TTR Class!
  19. #159
    06-13-2008
    Bronx, NY
    2,606
    There is not an issue anymore for the 02-03 galant for a fully 5 speed swap with cel fix and speedo fix.
    Dion and my self got the speedo working 100% with no issue and no low fuel problems.
    Very simple very clean fix
    What we did was we took the input speed sensor ground and relay power. The signal wire we reused it that is the white wire. Now two ways of doing this for the signal. Go to the pcm conector wire look for the white wire that goes to pin 103 on the pcm.
    Option 1
    Cut white wire on pin 103 and tap it to the green and yellow wire on pin 80.
    2
    Option 2 you could brige 103 and 80. W & G-Y wire. This option is what we did.
    You are all set.
    The hardest thing is to take out the blower motor. But is oem fix and is the right way.
    Speedo working on dash and pcm. Log speed on evoscan and it shows the right speed. I will pull out some diagram for easy visual.
    This work was done by:
    Triple Dimond Motors
    Dion aka Deeznuts - President
    Isaurio aka Isaurio - VP
    SOHC Turbo
  20. #160
    12-02-2008
    1,263
    That would be awesome bro bc im lost.lol
