Thread: Went to wire up the speedo...
Page 9 of 10 FirstFirst ... 5678910 LastLast
Showing results 161 to 180 of 195
  1. #161
    06-13-2008
    Bronx, NY
    2,606
    That would be awesome bro bc im lost.lol
    Yeah bro is simple. How is your g. Is been a while you dont post.
    SOHC Turbo
  2. #162
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    That would be great bro, and thanks for asking bout my car. Yeah shes all done but have alil problem with her =( Everything works out perfect but for some reason car dosnt want to start. It cranks over but not starting. Their is spark and fuel pressure but nothing is coming out of the injectors. I think its bc of the resistor box not wired up right bc I did get the immob deleted from ECU, but only thing is that I ran out of time and school came back.lol so now have work and school and no time for the car so what I did was sent it to TurboTrix to take a look at it but so far nothing....its been 3 weeks and they havnt called me so this week Im ganna stop by and see what they are doing.
  3. #163
    06-13-2008
    Bronx, NY
    2,606
    Yeah bro. I could say is the immob. If you using a evo computer there are 3 places to delete the immob. Is good idea to double check the resistor box. All signal goes to the resistor and the ground goes to the ECU. Keep me posted. I could help you in whatever i can.
    SOHC Turbo
  4. #164
    06-13-2008
    Bronx, NY
    2,606
    Here is the Video i took. Fuel is below half.. This is my 02 Galant with Stock computer
    SOHC Turbo
  5. #165
    So when I am running the signal wire to the yellow black c 17, am I supposed to cut the yellow black wire? Or am I supposed to simply connect the signal wire to that wire (with no cuts)?
  6. #166
    Get t-taps, and tap it in, NO CUTTING!
  7. #167
    Lmao
  8. #168
    04-02-2009
    Denver Colorado
    1,447
    Those things need to be banned
    T-Taps are great for quick circuit diag or other short term testing that is about it. Over time these things become loose, give intermittent connections and cause a number of headaches. Save yourselves the trouble and just buy the butt connectors, insulated or not...you will thank yourself should you ever have any wiring issues later.
    www.blackheartmotors.net
  9. #169
    I agree with you to a point but if you get the correct ones (not the ones they sell at walmart) then your good to go
  10. #170
    04-02-2009
    Denver Colorado
    1,447
    Doesn't matter which ones, when I worked for ATS Diesel we saw a lot of wiring issues over the 3 years I was there that were caused by these types of connections. You have to remember these types of terminals "pinch" into the wire jacket and make contact with the core. Over time the metal pieces start chewing into the copper core of the wire and breaking the strands of wire, ultimately causing intermittent contact issues.
  11. #171
    If you use a dissimilar metal, yes it will break the conduit as we do see that alot with the jets on harnesses that move quite a bit. But I have never seen it happen (yet) on a harness that is left alone on the jet, with the use of copper "t-taps" in the military.
  12. #172
    There is not an issue anymore for the 02-03 galant for a fully 5 speed swap with cel fix and speedo fix.
    Dion and my self got the speedo working 100% with no issue and no low fuel problems.
    Very simple very clean fix
    What we did was we took the input speed sensor ground and relay power. The signal wire we reused it that is the white wire. Now two ways of doing this for the signal. Go to the pcm conector wire look for the white wire that goes to pin 103 on the pcm.
    Option 1
    Cut white wire on pin 103 and tap it to the green and yellow wire on pin 80.
    2
    Option 2 you could brige 103 and 80. W & G-Y wire. This option is what we did.
    You are all set.
    The hardest thing is to take out the blower motor. But is oem fix and is the right way.
    Speedo working on dash and pcm. Log speed on evoscan and it shows the right speed. I will pull out some diagram for easy visual.
    Has anyone tried this? Is he saying that his method can both get rid of the CELs and fix the speedo? I am wondering about this because I noticed in one of his posts that he does not have any CELs. He also claims that he is still using the stock computer.
    btw. I am a little confused on what he is saying. Where does the signal wire connect to?
  13. #173
    Quote Originally Posted by prestosamsung View Post
    im lost myself! ive been waiting for a official how-to wire up the speedo on the 02s
    STAY READY AND YOU WONT HAVE TO GET READY!!
  14. #174
    06-13-2008
    Bronx, NY
    2,606
    This is only to fix the speedo on the 02 and 03. It would not fix any CEL INCLUDING the trani codes.
    Read it again a follow the instruction. Look around for diagrams and where things are located before you do the fix.
    SOHC Turbo
  15. #175
    ok so i got the wires set like you say but it still doesnt work....i read your post and thought for a sec the G-Y is pin 104 output shaft speed sensor, not 103 (input shaft speed sensor) so why are you tapping 80 into 103 wheni think you meant 104 because it is G-Y
    2002 Galant LS 3.0L V6 5spd, CAI
  16. #176
    06-13-2008
    Bronx, NY
    2,606
    We are reusing the wire from the A/T so you wont have to run any wires.
    U could use 103 or 104. Is the same signal. I used 103 and it works.
    Im going to write a better tutorial.
    SOHC Turbo
  17. #177
    06-13-2008
    Bronx, NY
    2,606
    Ok made this last night. For people that needs visual.
    This is with a 99-00 speed sensor connector 2.4L and V6. Same goes with other speed sensor pigtail
    For V6 Guys using a 3G speed sensor connector color goes as this
    B-W "black with white" = Power to relay Connect to input shaft sensor wire power
    B "Black" = Ground, connect to ground on input shaft sensor wire ground
    W-L "white with Blue" = Speed sensor signal Connect to input shaft sensor wire signal
    pcm plug side
    SOHC Turbo
  18. #178
    Quote Originally Posted by WhiteGalant View Post
    Ok here are the pics...
    ok i got mine working finally after so many times trying. i have this same set-up. from looking at the picture left to right
    Tan wire-SIGNAL
    Yellow wire- GROUND
    Black wire- POWER
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
  19. #179
    06-13-2008
    Bronx, NY
    2,606
    U got it working. Nice. What picture did you used?
    SOHC Turbo
  20. #180
    Hey bro I had my speedo working for a while, but then it stopped working after i raced this car, u got any ideas before i start removing my blower motor again to check connections?
