Thread: 1990 SOHC Manual
Showing results 1 to 4 of 4
    1990 SOHC Manual
    Hey Guys,
    I'm new to the forum. I'm actually new to Mitsubishi (my first one ever). I bought this car for my nanny to get back and forth from out house with. I don't expect her to drive the crap out of it but I do want to keep it running for a while. It has 258k miles on it. Supposedly it just had a valve job and "cylinder head work." I've heard that the timing belts and water pumps go out on these car ever 50k miles. Is this true? What else should I look out for maintenance wise? I'm sure you'll probably say everything on a car approaching 300k miles. Any help would be appreciated. Thanks Guys
    damn welcome. not so many sixth gen galants
    02-18-2009
    NEWBURGH, NEW YORK
    486
    gaskets. spark plugs wires . disbutor cap and rotor fuel filter and change the oil asap . because u can
    02-18-2009
    NEWBURGH, NEW YORK
    486
    i have a 6 gen and i did that . and she ran pretty good until my friend started driving her around and spun the rod bearing. its kool . im droping in the 4g63 dohc fwd motor in it now
