oh yeah my rims are 18X7.5 and when i push my car down in the rear, it doesnt hit the tires so im not sure if ill rub or not...
ok, i have the progress drop on an i4 and i have 18 inch rims with an offset of +45 and falken 225/40zr/18 tires.... but heres the problem, spring break starts sat and we are driving to daytona from tallahassee, about 3 1/2 hrs. if there are four of us in the car and all our ber and bags, will i def be rubbing? and if so how much damage is possible to my tires?? thanks for reading all of this....
I dont need to post my mods, i know i got the hottest galant in tally, and thats all that matters to me! http://photos.yahoo.com/fsubk
With stock struts and 4 people in the car, you will most likely rub when going over bumps.....
2001 Galant ES I4
Injen RD CAI
Kamikaze Headers
Brospeed Prosport Muffler
Progress Springs
KYB AGX Adjustables
Racing X Headlights
Smoked Tails
Custom Grill
Titanium Limo Tint
MOMO Shift Knob
Tenzo R Mean-6 18"
JBL 600.1
It shouldn't...maybe the occaissional bump but flat driving you should be fine.
thanks guys..i appreciate it...
Listen, I have Progress springs on a V6 with 18x7.5" rims, a +42mm offset and 225/40 tires. I also have a camber kit in the rear. I'm almost certain that without my rear camber kit, I would not rub like I do now, but the rubbing is very minimal. Since you have a +45mm offset, you are further away from the fender than I am and I assume don't have a camber kit, therefore I would be shocked if you rubbed at all. Your shocks are more likely to bottom out before you would rub.
