i bought this u think it will do the same trick?? it cost me like 17$ or should i consider buying peel and seal or protector wrap?
thanks guys... i have decided to do things the right way.. so i will be searching for some cheap stuff that is actually made for what im using it for.
2002 5spd swapped
under construction.....
well I think it would work but you might want to read what spd_frk wrote he is all knowing. (wanting to be just like him when I grow up lol)... But seriously he knows more about it than I do and I took the protecto wrap off my car after reading his post.
2002 5spd swapped
why not use dyno matt
- Chris -2006 Mitsubishi Eclipse GS 5MT: My DD
DRL Delete | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
Dyna mat is fine. I just got back from Home Depot and bought some Protecto wrap for the window siding. I was shocked the product was alot different from 5 years ago. It turned out they went cheap on us and replaced the aluminum shielding with......teflon sheets. Talk about cutting back on cost! I wouldn't recommend this product to anyone.
it feels like it has aluminum on it so idk if i should even try i only got 2 12"s in da trunk lol
i just have two 12" kenwoods powered with two 600 watt kenwood amps. sounds pretty good.
but i went ahead and bought the expensive dynamatt just to cut it down a little. i also removed the third brake light in the rear window since i have one on my spoiler because this was a big part of the rattle, although this isnt a option for all G's
2002 5spd swapped
I have 2 12' clarions and a 1800 kenwood in mine rattling is not that bad im gonna be removing my high mount has well when i paint n install my spoiler. just gotta sit on my trunk lmao although i would like to put some dynamat. about $360 installed the complete trunk
EDIT 12" lol my bad
sooo i put da 17$ stuff i actualy worked pretty gud da tar was thick thou but it got the job done i jus ordered a dynamat liscence plate kit jus to show off i guess lo jk
