Thread: Indiglo power wiring help needed
Showing results 1 to 4 of 4
    Hi All,
    Bought a set of indiglo gauges, just need a shred of advise wiring it,
    Have searched the forums and found some info but the wiring on mine seems to be different,
    Im assuming the part with the hole should be grounded on a bolt or some such, i just have no idea what to do with the other bit.
    As you can see there is a red and a black wire, im going to connect it to the dimmer rheostat wiring but the wires on that are green, black/yellow and black, which does the red go to and which the black?
    Thanks guys
    Ohh Yeaah almost forgot, i cant get the bloody needles off either
    11-14-2007
    Boothwyn,PA
    719
    This is ALOT different then the one I bought.. Mine had a wire for the ground and then a red wire that I just plugged right into my fuse box....
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    the gauges' red wire should be connected to the green/white wire in your fuse box area. that is your parking light wire.
    Quote Originally Posted by JoeRad View Post
    Don't take the needles off. Just slide the needles thru the holes on the gauges
