Thread: just installed
Showing results 1 to 20 of 22
    just installed
    the lowering spring is finally installed,finally i can post some pic now i cant post pic before cuz my computer is down,,,
    What kit did u use? Works or ?
    Patrick
    2009 Galant Ralliart Black
    http://www.pwdphotography.com
    TGC Regular stvn_mj's Avatar
    07-30-2008
    Avondale, Arizona
    961
    The drop looks good but dang those wheels look tiny on the 9G.
    looks really good but i would definately go with a bigger rim
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Quote Originally Posted by stvn_mj View Post
    yeah looks great though i havent seen a 9g dropped or anything in my area just with rims. 19s would look good or maybe even 20s...imo
    FreakyDeaky
    2kG 6g72/74 5 speed
    Quote Originally Posted by procksa49er View Post
    i have h tech tein springu wont regret having it
    imma gonna sell my rim and get motegi 19 inch rim..thanks guys for the inputs....
    Make sure you add pictures of your ride in our official 9g picture thread!
    11-13-2007
    -OKC-
    3,970
    19s or 20 inch WHEELS (not rims) would look the best.
    very clean 9g
    04-29-2009
    3,600
    Its a habit in massachusetts we call them rims... I know there really called wheels but like I said its habit... I'll try to rephrase when I post here. My bad...
    FreakyDeaky
    2kG 6g72/74 5 speed
    i might go up 19s soon,but im afraid that the tires will rub in the fender,,but down the road will to go up for 19s WHEELS,,,
    how to put pics in the 9 g threads???
    if you guys dont mind any sound setup suggestion??thankyou
    04-29-2009
    3,600
    Well I'm sure there's a lot better than I have but I have 2 12" clarions in a closed box and a 1800 kenwood amp and I'm very pleased with it
    FreakyDeaky
    2kG 6g72/74 5 speed
    are you the one who make the box or you bought it custom made?? cuz there is one custom shop where willing to do custom made fiberglass layout..im thinking like 2 subs and amp,,one on each side and amp in the middle,,hes gonna charge me 500 for it including installing it but the components is out of my pocket..
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Quote Originally Posted by madkilla View Post
    Oooooo I didnt even see this...i likes alotsssss. Great job looks very nice.
    thank you sir...glad you guys like it
    rocgalant
    Tirerack.com says you can put 19s on that biznitch. You should be good. I think another dude on here has 20s too with no adjustments needed. I'm not too confident about 20s and how that would work out.
    i have the tein s tech i have 20 inch wheels and it dont rub
    Quote Originally Posted by rude View Post
    tein h tech is more lowered than s tech tein
    01-08-2008
    Levittown NY
    2,786
    I believe that Ralliarts had 18s stock so you can probably do 19 or 20 without issues as long as you get right tires and wheel specs.
    9th Generation: (listed in italics are sizes that best fit)
    Original: 215/60-16 (26.15") **Original DE & ES sizing**
    Plus Zero: 225/55-16 (25.75")
    Plus Zero: 225/60-16 (26.62")
    Original: 215/55-17 (26.31") **Original SE & GTS sizing**
    Plus One: 225/50-17 (25.85")
    Plus One: 215/60-17 (27.15")
    Plus One: 235/50-17 (26.25")
    Plus Two: 235/45-18 (26.33") **Original RalliArt sizing**
    Plus Two: 225/50-18 (26.85")
    Plus Two: 245/45-18 (26.68")
    Plus Three: 235/40-19 (26.40") **Recommended upsize fitment
    Plus Three: 225/40-19 (26.08")
    Plus Three: 225/45-19 (26.97")
    Plus Three: 245/35-19 (25.75")
    Plus Three: 245/40-19 (26.71")
    Plus Three: 255/35-19 (26.02")
    Plus Four: 225/35-20 (26.20") **Recommended upsize fitment
    Plus Four: 235/35-20 (26.44")
    Plus Four: 245/30-20 (25.79")
    Plus Four: 245/35-20 (26.75")
    Plus Four: 255/30-20 (26.02")
    I would go 235/35-20 or 235/40-19 :)
