Thread: my g died on me tonight help!
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 47
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    so i was driving and i studdard then died.. the car turns over but does not fire dash lights came on (oil, battery, ses, etc.) so i know that i do need new ciol mpacks thinks to me reading up on other ppls threads they have posted, would this be the problem or is it something worse? i also noticed that the last day or so i have heard i noise that is unusual, sounded to me like something was rubbing on one of the pulleys the noise went with the rpms of the engine.. could this be an issue? i am in a really big bind not having my car this is my only form of transportation i cannot work without it. please help me!
    Bronx NYC (reppin)
    3,489
    when you try to start does it gives a chugga chugga sound or a whirling whine sound>?
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    03-15-2010
    nashville, tn
    505
    it sounds normal (chugga chugga) it sounds to me like its not firing but i am not for sure but no whining for sure.
    04-29-2009
    Holyoke,Massachusettes
    3,600
    my G died last week. check ALL the fuses mine died the same way and it was doing the same as yours. if the fuses are fine it may be the timing belt.
    FreakyDeaky
    2kG 6g72/74 5 speed
    Quote Originally Posted by Corey2000Galant View Post
    Replacing blown fuses won't cure a engine knock problem or other noise. If it threw the timing belt the engine may as well be considered junk, and thereby replaced. Not necessarily that it can't be repaired, it is just more expensive than finding a decent used engine with half the mileage for less than replacing the timing belt in his engine.
    03-15-2010
    nashville, tn
    505
    ok i am going shortly to go see if i can figure something out on it that is something i haven't thought to try thanks and how do i check timming belt i know where it is and how to get to it but not what to look for if its bad? only if its broke.
    03-15-2010
    nashville, tn
    505
    i hope thats not the case the car lot can take it back if so, lol.
    11-13-2007
    -OKC-
    3,970
    Change the coilpacks, plug wires and spark plugs. That should restore the Johnny 8G.
    04-29-2009
    3,600
    i didnt see the engine knocking part... just breezed threw the reading... my bad... its just that my G died almost exactly like his minus the noise though..
    FreakyDeaky
    2kG 6g72/74 5 speed
    03-15-2010
    nashville, tn
    505
    yeah i went to check it out today and 2 out of 4 plugs fired. the two that did was on the same coil...
    04-29-2009
    3,600
    Quote Originally Posted by djhah View Post
    so its all fixed then???
    FreakyDeaky
    2kG 6g72/74 5 speed
    03-15-2010
    nashville, tn
    505
    not yet i don't have the money to get every thing today tomorrow i am going to borrow the money from my sister in law tomorrow so i can give it a try. i hope this fixes it.
    04-29-2009
    3,600
    So let us know if you fix it.
    FreakyDeaky
    2kG 6g72/74 5 speed
    03-15-2010
    nashville, tn
    505
    definatly will i hope this is the problem it will kill me to not be able to drive it, i am already having withdraws, lol.
    03-15-2010
    nashville, tn
    505
    so i did the coils and nothing i came to the conclusion that there is not any power coming to the coil on my passenger side any ideas there is power to the other, but it is not starting still, so i have ruled out the coils wires and plugs, what next? now its frustrating me to not know
    04-29-2009
    3,600
    How about the fuses? Did you check those?
    FreakyDeaky
    2kG 6g72/74 5 speed
    03-15-2010
    nashville, tn
    505
    yeah checked the ones under hood and on dash nothing looked blown to me
    03-15-2010
    nashville, tn
    505
    fuses are all good under hood and dash this is maken me upset that that i have not got it yet i also checked the relays
    try switching the coils around and see if the misfired cylinder will jump, as well. for that, reset the ecu, switch coils, drive so the CEL comes on again and read the new code.
    03-15-2010
    nashville, tn
    505
    i did switch coils with new ones i tried resetting ecu still not firing on the passenger side coil no matter how i swapped them around i am at a loss here i am having to borrow a family members car for work, before i got that it was a bike i haven't rode a bike in years.
