Hi Guys ,
I bought a 2000 ES almost a month ago , and the previous owner managed to lose one of the Master Keys and Break the other one , so all I got now is the valet key which doesn't work niether on the trunk nor on the glove box .
So I ordered a transponder Key from Ebay :
Code:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItemVersion&item=110524688751&view=all&tid=518751163001
I took the trunk lock cylinder out and had it rekeyed because I wanted the blank key made from the Master key not the Valet key so it works with trunk and glove box too . that cost me $ 35 .
Then he told me it's goanna cost me $ 75 more to make a duplicate from the key he just made for me and transfer the codes from the valet key to it .
After I showed him the key that I got from Ebay , he took the from me and went to the back of the shop and came back after couple of minutes and says I checked the and it's no good , it has already programmed and I can't redo it again .
So it got me thinking how is it the a blank key has codes on it .
I took the key to some other locksmith and he said it's not "JMA" key and we can't do it , our machine only does JMA keys .( which is the same machine that the first locksmith had ). I asked him to check the key anyways , he checked it and the key showed codes . But he said it can't be done with this machine , this only does JMA keys .
So which one is it :
1 - The key is no good and has already programmed when I got it .
2 - The key doesn't work with JMA machines cuz it's not "JMA Key" ( as the 2nd locksmith said) .
3 - He took my key to the back of the shop and programmed it with some other key , so I have to buy another one from him .
sorry it turned out to be such a long post .
I wanted you guys to know the whole story .
Many thanks in advance.
