Thread: Gearbox Problem ( Help me ! )
Showing results 1 to 3 of 3
    Kavosh_h
    Dear Friends.
    To upgrade my Car (Mitsubishi Galant 7G 1993) I have bought a 6A12TT(Twin Turbo) Engine with a AWD Gearbox (W5M33)
    the previous engine was a 6A12 with an automatic FWD gearbox (F4A23)
    Now I have a problem for which I need your Help:
    How can I change the System on the AWD gearbox and make it functional as a FWD gearbox
    If I want to change the system of the car and make it into an AWD , I need a rear axel and any other parts to do the same , How can I purchase these parts and from where ? Is this experiment possible?
    Option 1:
    https://www.thegalantcenter.org/showthread.php?t=39610
    Its not very good for daily driving. If you just install the AWS tranny e/o the rear end components itll blow up cuz there will be no load to the rear. The tranny will try to keep the 50-50% front-rear ration and transfer most of the power to the rear thinking its constantly slippin....and.....BOOM, Some people weld the center differential and stuff, but IDK.
    option 2
    https://www.thegalantcenter.org/showthread.php?t=34981
    You need either 7g VR4 or 2g GSX (manual trans) rear end, transfer case, drive shaft
    Kavosh_h
    Thank you for reply :)
