Thread: Best Sub For Amp ?
Showing results 1 to 11 of 11
    Best Sub For Amp ?
    Just picked this amp up at a local shop that was going out of business for $100. I am building a custom box for a single 12" sub in the corner of the truck to save space. My question is what would be the best speaker to pair this with, and the correct way to wire it up, for optimum power and quality.
    Specs:
    Bass Inferno BI 2500 DX
    Rated power: 14.4 volts
    1 x 1250 Watts @ 4 Ohms
    1 x 2500 Watts @ 2 Ohms
    Class AB Circuitry
    Audiophile grade components
    High Efficiency mosfet outputs
    On-board (fully variable) high/low x-over
    Enchanced dynamic performance
    2 ohm mono capability
    Bridgeable
    Bandwidth 20 - 50 Hz
    X-over slope: 12 dB
    Bass Boost @ 45Hz: 12 db
    Input Sensitivity: .2Mz - 5V
    Input Voltage: 14.4 V
    THD @ rated power: <0.05%
    http://www.bassinferno.com/products-...ion=Amplifiers
    09-10-2003
    Charlotte, NC
    4,463
    that's gonna be a mighty strong sub if it states 2500 at 2 ohms, which would be the best way to wire. You'd want to get a dual voice coil 4 ohm sub, or a single voice coil 2 ohm sub and wire it bridged to the amp. The name brand that comes to the top of my head for that much watts are Kicker and JL Audio.. only because i haven't done sub research in quite some time. let me dust my shoulders off and review
    09-10-2003
    Charlotte, NC
    4,463
    while I look, this is how you'd wire the subs
    4 ohm dual voice oil
    2 ohm single voice coil
    Personally I'd go DVC 4 ohm
    You might look into a kicker L7 also.
    2001 Mitsubishi Galant-Totalled..=(
    1987 Cheverolet IROC-Z Camaro-TPI 350
    1989 Nissan 240sx-built SOHC-Trade for Honda
    1999 civic Hatch B20vtec- current
    Lookn for galant to build. .
    09-10-2003
    Charlotte, NC
    4,463
    i was assuming that since he was building a custom box he was looking for a round sub but an L7 would also suffice, that's what I run
    why not just match it up to the same brand subwoofer?
    also those amp ratings are suspect. i don't think those are RMS but rather peak. you could probably get away w/ a sub w/ half those numbers since i don't believe that amp is pushing those numbers RMS.
    X2^^
    New Member
    04-24-2010
    Virginia 24501
    64
    I'd go type x from Alpine durable sub I beat the shit out of my type S 12's from Alpine and the cones are in perfect shape
    G57 Dont hate me because you dont know me
    09-10-2003
    Charlotte, NC
    4,463
    their sub doesnt look bad, cant find an RMS rating though
    http://cgi.ebay.com/DB-Bass-Inferno-...item1e5baf5211
    lol look at stylz with all the ifon lol. subscribed for info!
