Thread: A/T Fluid
Showing results 1 to 10 of 10
    TGC Regular kondypl's Avatar
    03-08-2009
    Chicago , IL
    412
    A/T Fluid
    My transmission is a little rough on me so I wanted to flush my A/T fluid and change transmission filters. I heard that if car didn't have A/T fluid flushed in longer then 60,000 miles you shouldn't do it because your transmission might die. I know for sure that my G had A/T fluid flushed in 2001 at 30k miles and I don't if it had transmission touched ever since then. Right now the car has 90k miles on and I want to flush fluid and change filters , should I do it , or it might kill my transmission??
    if its shifting rough, check the fluid level, if it's low a simple fill to the proper level might be sufficient to fix the problem.
    Jigz-TGCIL Sosick Motorsports
    it should be safe to flush at 60k miles, also use the diamond sp3 atf from mitsu
    03-08-2009
    Chicago , IL
    412
    Quote Originally Posted by LatinoX20 View Post
    I have 90k miles
    Quote Originally Posted by kondypl View Post
    I have 90k miles
    well u said it was flushed at 30k, so if you flush it again at 90k then it still good
    its a 7g. it will start shifting rough at some point of the time.
    You wanna smooth thing out a bit, get a bigger oil cooler. when I changed mine it made the whole difference in the world. Id like to believe that it made my tranny last to 220k miles. It was still good at the time of 5 spd swap
    03-08-2009
    Chicago , IL
    412
    but it still didnt answer my question , is it safe and should I flush the A/T fluid and change the filters
    yes, go ahead
    03-08-2009
    Chicago , IL
    412
    thanks for responds , I'll do the flush next week and keep you updated.
    07-16-2006
    Cocoa, Florida
    791
    5 speed ftw :)
