Thread: Mivec Heads
Showing results 1 to 12 of 12
    Mivec Heads
    Hi all
    I have a 2004 Galant 3.8 that I am swapping into my Avenger. Picked up a pair of MIVEC heads for $250 because one has 2 bent valves.
    I need to know if the internals are identical between the 3.8 from the Galant and the 3.8 MIVEC motor.
    Are the heads physically the same size as the NON-Mivec heads?
    2013 Viper GTS 600whp 157.89mph 1/2 mile best
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    1998 and 99 Dodge Avengers
    04-02-2009
    Denver Colorado
    1,447
    Everything is the same. Though I would suggest ditching the MIVEC and use the Non-Mivec heads. Why? Because there are no aftermarket cams out there for the MIVEC heads. RPW was going to make them but the price and market just would't have played in their favor.
    Best bet is to swap in a set of 262s, or 272s from RPW on the Non-MIVEC Heads. You will find them listed under the 6g75, otherwise even a set for the 6g72/74 will work as well
    www.blackheartmotors.net
    I am not sure i'll even go with cams though. I want the extra 30hp the Mivec heads deliver. I will then have them ported and polished.
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    05-03-2007
    Socal/Central Coast
    3,803
    How do you plan on using the MIVEC?
    Megasquirt II
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    04-02-2009
    Denver Colorado
    1,447
    I guess if you don't want any other cams then the MIVEC would work for you. The MIVEC is good as long as you control it. A lot of people have messed with the "activation" point of the MIVEC and found the factory set it up right the first time at around 4k rpms.
    yeah I have read that. I think with porting the mivec heads- a good free flowing exhaust- possibly a larger plenum and TB- i'll be happy. :dunno:
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    You could get cams specially produced if you can find a company that would be fine with doing a single order. Most would rather make a batch of these items then just a set for one car.
    Is the lower intake manifold the same on the 3.8 galant V6 and the MIVEC eclipse 3.8??
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    04-02-2009
    Denver Colorado
    1,447
    Ports are larger on the MIVEC heads, thus the lower manifold ports are also
    Ok so is the 3.8L galant lower intake manifold the same as the eclipse 3.8L one but with only larger ports?
    Reason i'm asking is because i am going to have both intakes ported while dennis is doing the valve job and port/polish. I don't want to send him a lower intake manifold that is not going to work with these heads.
    2005 Ram SRT10
    2005 Mustang GT
    2016 Maxima SR
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by skyy406 View Post
    That is correct. Either one will work, and if you are having PnP work done he can certainly port the non-mivec lower to match up
