Thread: Shes dirty and dented, but still mine :)
Showing results 1 to 9 of 9
    01-08-2008
    Levittown NY
    2,786
    Adjusted headlights here is light output top is low and fog, bottom is highs only.
    Experienced TGC Member Bloody Arro's Avatar
    04-14-2009
    Highlands, Tx
    1,066
    I love your fogs. And nice new sig also.
    And fwd grocery fetters are fun, you wouldn't be on this forum if you didn't agree
    Quote Originally Posted by 8thLS6 View Post
    Tuning to me is like magic... I don't understand it but it makes things happen lol
    01-08-2008
    Levittown NY
    2,786
    Thanks Arro
    03-12-2007
    Dallas TEXAS
    2,041
    thats the beauty of that color ... you cant tell shes dirty till you touch her lol looking good man
    04-14-2009
    Highlands, Tx
    1,066
    Red cars easily get dirty..
    so the lows go off when u turn ur highs on? to fix that so the low stay on, check out my JDM headlight tutorial and look for the diode/relay trick. those that do the JDM conversion do this in order for the heads to function like they were meant to (dual beam functionality vs. single beam hi/low). the stock switching does that because the H4 bulb functionality turns the low beam filament off when the hi beam filament goes on (since they are both in the same bulb and it would overheat if they were both on), but since you now have separate low and high beams, they should both be on when u switch to high beam.
    09-25-2006
    Central, Cali
    1,145
    makes me feel better knowing im not the only one ding up here lol
    still looking good
    03 I4
    01-08-2008
    Levittown NY
    2,786
    Yeah I am wiring it to that when I wire the HIDs to battery I dont want to strain stock harness too much since I have 3 sets of HIDs up front
    Quote Originally Posted by 03-Galant-ES View Post
    yeah ideally HID should always be run off relay harness directly to the battery (only drawing current from the OE harness to trigger the relays). i have had 3 HID sets concurrently on my car for more than 5 years... all are running off relay harnesses, no blinking, no start up issues, etc. good news is when you do go to full relay harnesses, you will only need a single diode to bridge the triggers and it makes everything so much simpler. u'll see what i mean when you rewire your heads.
