Thread: problem with ECU part no. MD189548
Showing results 1 to 4 of 4
    Good Day!
    I have a problem with my Galant V6 SOHC 2.0 24Valve... the 3 coils are new but it misfire there are only 4 pistons working, the 2 piston are not working.... I think the problem is in the ECU with part number MD189548... can the electrician fix it or i'm going to buy a new 1? 50/50 decision... any advice... can anyone help me.. please?
    angelnids
    *Galant Viento 1996 V6 24V 6A12 Engine 5 Speed Manual Trans*
    First the cylinders that don't appear to work should be checked for compression, fuel, and spark. Then you can move to condemning the ECU.
    my mech check already the compression & the fuel, he said it ok.. i replace all 6 spark plugs but then nothing change.. i'm running rich coz in the exhaust i smell lot of fuel that did not burn..
    what do you mean condemn? change it to a new one?
    angelnids
    Condemn meaning blaming the ECU, he wanted you to check the other options he mentioned before "blaming" the ECU.
