put bulb in head light, connect bulb to ballast, connect ballast to harness, secure everything, turn on car, turn on lights. Done.
I just order HID lights for my fogs (H1)
Problem is how the hell to you install them.
Any help will be great
i already have hid's for my headlights these are for my fog lights. They its a H1 but that cant be right
hmmm...I am not sure about 9G but if 9g has H1 fogs its just as easy. The bulbs have same connectors to ballasts as heads and to hook in the positive and negative its similar as long as your car takes h1 fogs.
similar to this my highs and lows are h1s.
This top pick is the h1 the bottom pic is the 9007 bulb, my problem is that when i take out my fog light bulb and insert the hid bulb that u see in pic 1 there no way to attach the bulb. In pic 2 at the bottom of th light theres lil inserts so u can twist the bulb and it locks in. th H1's dont have that so how the hell do i install these things.
Can you please post a pic of the halogen bulb that was on the fog before?
4g64T 5spd
ill post some pic's later today i dont have my car with me now. AND i just got off the phone with ddm im gonna swing by with my car later today and have them match the bulb's and get me the right one's. Ill keep you guys posted
who told you you needed H1?
nvm I am checking right now and it looks like it does take H1 so why are you posting 9007?
What year/engine is your G cause my source is showing me its a 9145 fog light for the 07 v6
k checked your garage the H1s are right. If you can take some pics I can walk your through it I think
Tell u the truth i tried to do it myself but DDM tuning and HIDextra.com both told me u have to pull out the h1 bulb cut the base and insert the hid then wire the HID kit to the stock light wiring. I SAID SCREW that, i call a local shop and then installed the lights for 25bucks, im Happy, Thanks for all the help Guys
Im gonna take some pics of the car tonight and ill post them later
I got all this work done this weekend What do u think??
Bright
Hey guys, can you help me get HID headlights for my 8g Galant ES. I dont know where to get them, I have seem some nice headlights on the intrnt but Im not sure if these sellers are real. Anything helps. Thanks.
Freehand, how did they end up mounting those bulbs? For those of us who want to swap for HID fogs can save the $25 if you can describe how they mounted them even in general detail
Blue Shitz yo
Sry it took me so long to get back to u guys. You take off the stock bulb and cut it so theres a nice hole then you insert the hid and use the rubber piece to hold it in place they pop it back in. Ill try to get a pic for you guys tomorrow
