Thread: 6G75 8G Action Videos
Page 2 of 2 FirstFirst 12
Showing results 21 to 30 of 30
    Nice vids man!
    04-02-2009
    Denver Colorado
    1,447
    He's actually running the 74 injectors I believe? I wonder how the AFR is doing right now with no tune. For the 6G74 swap he would be running pig rich, but I wonder how that extra .3L affects it
    Even with the 74 injectors, the CR on the 75 (10:1) is higher than the 74 which I believe was 9.5:1 correct?
    The heads on this engine is what truly makes it run like a raped ape. From the factory the 75 runs rich in the fuel maps, and timing is anywhere from 4-6* different from the 72 ignition maps.
    www.blackheartmotors.net
    08-18-2004
    Charlotte, NC
    1,029
    Are you running the 75 injectors? Tune it with something...anything!
    1994 GS FYI
    DSM/CSM Manuals
    What year car did your 75 come from?
    I'm sure the P0420 is only due to removing the cat. It seems fine so far, though I definitely do plan on getting the Emanage Ulti this weekend anyway. Besides, if it blows up in the meantime, it just gives me a good excuse to go MIVEC. There are plenty of MIVEC 75's with under 20k for less than $1000.
    2002BlackDragon, the engine came from an '04 Galant.
    got pics of the engine bay?
    Quote Originally Posted by Da_silvagride View Post
    https://www.thegalantcenter.org/show...t=37838&page=6
    All I took was on that page. It's still dirty as hell. I need to get motivated and clean it up a bit, and switch a few parts (valve cover, plenum, etc.) but when I do, I will be sure to take much better pictures.
    04-02-2009
    Denver Colorado
    1,447
    Well if the cat was removed that would explain the code. Just get some spark plug defoulers in there and it will solve that code issue.
    I wouldn't even bother with spending the money on a MIVEC, IMHO its a step back from the current possibilities. With the Non-Mivec you could get better results with a set of stage 2 or 3 cams from RPW.
    Sounds awesome. I looked at your videos and noticed you stole my name! I've never met another person with my name.
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Holy shit!!!!! These are the best vids I have ever seen a Galant in action. Awesome job man two BIG thumbs up!!!
