Thread: 15" Kicker L7. Box help?
Showing results 1 to 9 of 9
    Hey, I've got an '08 15" Kicker L7 and a Power Acoustik BAMF-2000/1D amp. I'm in need of specs for a ported box that won't be too small. My friend's got an Impala with a 3 cubic foot box, and the sub doesn't have enough room. I don't want that to happen to me. The trunk seems really small to me, though.
    Forgot to mention I've got an '03...
    I dont see how 3 cubic feet isnt big enough for an L7 15...that seems like its about right..possibly jus a hair small...maybe his port isnt right for the sub..
    2001 Mitsubishi Galant-Totalled..=(
    1987 Cheverolet IROC-Z Camaro-TPI 350
    1989 Nissan 240sx-built SOHC-Trade for Honda
    1999 civic Hatch B20vtec- current
    Lookn for galant to build. .
    have you looked at the kicker website? it should give you the specs you need
    Quote Originally Posted by littlerick View Post
    Min Rec Vented Box Volume (CU. Ft., Liters)** 3.0, 85.0
    Max Rec Vented Box Volume (CU. Ft., Liters)** 6.0, 169.9
    Looks like 3 cubes is the min... good luck trying to fit in 6 cubes if you want the max... lol...
    www.edelhausrottweilers.com
    Yeah, I'm aware of the recommended size of the box. I was wondering HOW to design the box to achieve the size. I was hoping for at least 4.5 or so.
    04-10-2005
    NYC
    3,695
    i would make a template using cardboard and trace out the trunk. to get the most out of the space you would have to build a box inside the trunk.
    Quote Originally Posted by MisterDeadeye View Post
    Here is what a 2.7 cube for a 15 looks like...
    Now from experience i can say you should be able to get a 4 cubic foot box in...if each measurement is percise...the box i was haven trouble with was atleast 5 cubic feet an it was REAL close to goin..but jus a hair too much.
    just take out the back seat...makes it easier lol
