You will still need your stock ecu and evo ecu to run boost and auto. You can buy a boomslang harness for like $350 that runs the correct pins on both ecus so that you can tune and your car still works. Then when you go 5spd you either have to rewire to delete auto ecu or buy another boomslang harness for 300.
I almost went turbo with auto, but I decided to go 5spd first. I just need a few more parts for both projects and they will be underway.
