Thread: Five speed swap help
Showing results 21 to 40 of 50
    05-03-2007
    Socal/Central Coast
    3,803
    14mm socket + breaker bar is your friend. Those bolts were only torqued to about 60 or so ft lbs back at the factory, but that was like 10 years ago. Those things will be pretty tight when you try to loosen them now
    I have a question for you 8g guys....... yea
    So the passenger side half shaft is two pieces with IDK WHY THE HELL THEY DID THAT CRAP. So the half that goes into the trans has to be the manual eclispe one but the bracket that holds the bearing does not line up on the block which is odd cause well the trans and the engine are the same. Any ideas on what the problem could be im thinking i need to disassemble that bearing bracket and get it to sit back a bit further????
    1996 galant s
    05-03-2007
    Socal/Central Coast
    3,803
    whoa whoa what do you mean it's two pieces? and how far off from the mounting holes on the block is it?
    Okay so you got a half shaft with the bearing and bracket still attached from the JY I assume? If so, you just bolt that whole thing up and then attach the normal driveaxle. Or did you take something apart?
    he said that we had to switch the brakets plus the mushroomed over the threads on the half shafts so we replaced them with new ones. Now we have everything back together, when we put it in the trans the mounting bracket is not lining up right.
    1996 galant s
    05-03-2007
    Socal/Central Coast
    3,803
    so what exactly from the A/T are you using and what from the M/T?
    TGC Regular bsilver23's Avatar
    04-06-2009
    Mequon, Wisconsin
    584
    we are using the half shafts from an eclipse and the passenger side intermediate shaft from the eclipse also
    Bryan - TGCWI - 6g72 5 speed
    http://www.cardomain.com/ride/3376567
    05-03-2007
    Socal/Central Coast
    3,803
    ahh this is confusing. Okay you are using both the drive axle and the intermediate axle shaft from the M/T Eclipse. You swapped over the bracket for the intermediate shaft from.. what? any pics of what's going on?
    new problem, we are bleeding the clutch system, the old slave was bad picked up a new on for 20 bux but still after bleeding it for a while it is not working properly, how does it engage with the clutch fork? the slave and everything works properly but will not move the clutch fork, i thought that the fork should move back and forth with the rod from the slave. Please help me if you can maybe it is working the right way but i dont think that it is cause the throw out bearing will not be working right.
    1996 galant s
    05-03-2007
    Socal/Central Coast
    3,803
    You know the little black lever that the slave pushes? have you pushed that to the right yet to engage the TOB to the pressure plate? Then fill the hydraulic system and bleed it. After you're done bleeding and you push in the pedal, is there any fluid coming out anywhere? Is the slave rod moving at all?
    04-06-2009
    Mequon, Wisconsin
    584
    Forgot to put this little circle thing on the end of the TOB. Now we have to remove the transmission again to put it on. That is why the fork would not catch onto the pressure plate
    ^the pivot ball? oh snap... lol
    05-03-2007
    Socal/Central Coast
    3,803
    circle thing on the end of the TOB? I have no idea what you're talking about lol
    04-06-2009
    Mequon, Wisconsin
    584
    its okay we got it figured out..just finishing up now
    04-06-2009
    Mequon, Wisconsin
    584
    swap finished!! but the brake pedal was kinda stuck down and i didnt adjust it prior to driving the car....so i pretty much messed up my pads and rotors.
    05-03-2007
    Socal/Central Coast
    3,803
    all right! I guess your axle problem magically went away? lol
    now break in that clutch, replace those pads and rotors, then have fun :)
    Yea didn't know that the v6 was a pull style clutch had to put the engagement ring in works well now that it all adjusted but yea brakes where a bit messed up lop three times in and out with that trans to get it right lol I'm now a pro at it
    1996 galant s
    04-06-2009
    Mequon, Wisconsin
    584
    when we were driving the car, the speedo wasnt working...mitch hooked up the speedo harness on the car to the plug on the trans, is that right or is there something different you are supposed to do?
    05-03-2007
    Socal/Central Coast
    3,803
    that should be it for the speedo. I'm not aware of any speedo problems for the 99-01
  19. #39
    congrats!
    Jigz-TGCIL Sosick Motorsports
  20. #40
    speedo sensor on the trans could be bad.
