Thread: Car Bogging down under boost?
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 78
    I was on my way to work today, doing about 40 on the ramp to get on the freeway. When i accelerated under boost, i felt the car hesitate like it was bogging on me so i let off. Right after i got a code P0303, maybe the plugs?
    00 Galant ES Turbo/5-Speed
    13 GTR
    01-08-2008
    Levittown NY
    2,786
    3rd cylinder misfire...I would def check plugs and wires. Also if you have an AFR gauge how were the numbers and do a compression check as well on all cylinders.
    how many miles you got on it ron? plugs, coils, and wires replace them if needed
    84K on the car, about 10K after the turbo with these NGK plugs/wires. That might be it, i'll pull them this weekend, never swapped them before should be a fun lesson haha.
    13 GTR
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Check your plugs first to see what condition each one is in. Its very simple to take the spark plugs out and put back in. Just make sure everything goes back the way it was....VERY IMPORTANT!!!
    Sounds like what i was having where the spark was being blown out. Change the plugs.
    05-31-2005
    4,735
    If those doesn't work, check the head light fluids. Those could be a ish to do. good luck :p
    Now my car started to bog down so bad, i cant drive it anymore. Also at idle its getting VERY lean 16.1 etc. If i rev up, it feels like its in limp mode.
    I removed the plugs, this is the result. think its just the plugs or something more? I have to order some tube-seals.
    13 GTR
    Anybody?
    13 GTR
    needs new tube seals. plug #3 looks like it ran a little hotter than the rest. and youre missing the tip of spark plug #4. lol
    Yeah #4 is missing the tip, wondered how that happened. Tube seals are only sold only at dealer? or can i get them from pepboys.
    13 GTR
    04-10-2005
    NYC
    3,695
    you can get them at your local store...they come with the valve cover gasket kit. i dont think i payed more then $15 for my v6 when i changed everything.
    08-04-2003
    NY
    4,344
    If the tip of #4 is missing it could have burned up from being so hot. When the tuner killed my old motor on the dyno, all 4 plugs were toasted, no electrode or anything left, it looked like a screw.
    It might be as simple as changing the plugs and/or coils. When the car was running good did it normally run rich? My car ran rich like 12.8-13.5 while in vacuum and I killed a set of NKG BPR7ES's in about 150 miles. I was misfiring, the car wouldnt idle, at one point it wouldnt even start, new plugs, all problems went away. You may want to also try going down one level to a colder plug too.
    99' Galant ES
    4G64/63T
    AEM EMS
    Thanks for the info guys, Ill pick up the gasket this week. Stewi the car did run rich, 12.4-14.3. I had these current plugs for about 2+ years or so. In the last couple months, i did notice misfiring, but just shock it off. I guess this was the issue all along then. Yeah ill try 1 level down plugs aswell. Also its better to replace all 4 plugs? compared to just 1 or 2?
    13 GTR
    08-04-2003
    NY
    4,344
    Yeah always replace them as a set.
    99' Galant ES
    4G64/63T
    AEM EMS
    2 years is a long time for plugs in a turbo car. Replace them with a set of NGK plugs one step colder and correctly gapped.
    Currently im using the NGK colder Plugs BKR7E, So go down to the BKR8E? The gap is .039 -.043 correct?
    Since were on this topic, how many miles do you guys usually replace your plugs?
    13 GTR
    since they are soo cheap, usually do it twice a year
    08-04-2003
    NY
    4,344
    Thats a big gap. I gap mine around .030
    99' Galant ES
    4G64/63T
    AEM EMS
    Mine are gapped to .028
