Thread: Car Bogging down under boost?
Showing results 41 to 60 of 78
  1. #41
    08-04-2003
    NY
    4,344
    Brian, you wanna take a ride out to Delaware this weekend? Its 2 hrs from NYC. Not too bad.
    Ehhh. If its the tune tho, I dont know SHIT about emanage, if he had AEM I could mess with it a little, but Emanage is foreign to me.
    99' Galant ES
    4G64/63T
    AEM EMS
  2. #42
    it beats trying to guess whats wrong his car from over the internets
  3. #43
    12-27-2005
    Charleston SC
    1,520
    When you removed the plugs are you sure you wired the plugs up correctly? I swear my car did that same exact shit when i first did my turbo build and like a jack ass i crossed 2 of the plug wires. Afr was lean, rich, blah blah blah all over the place. That ticking is from the cylnders not firing correctly. Good luck
  4. #44
    Is the fuel pump stock?
  5. #45
    yeah, i marked all wires before removing them. The same issue was happing before the swap of plugs.
    Seth, I have an Walbro 255 LPH Fuel Pump
    00 Galant ES Turbo/5-Speed
    13 GTR
  6. #46
    12-27-2005
    Charleston SC
    1,520
    Maybe u have a bad coil. Good luck man.
  7. #47
    I been thinking its the coilpacks, im trying to locate some which I can test. I remember alot of user's had issues with emange +coilpacks frying, which i never did. But maybe now that might be the issue. Been running the same coilpacks for 90K miles, +2yrs of boost
    13 GTR
  8. #48
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Maybe its time to go Evo 8 ECU. I have a spare on sitting on my desk right now you can have for free. (just kidding Jesus!!) It belongs to galantfan88. lol[/QUOTE]
    HAHA I just saw this right now, your to damn funny Aaron.lol
    Quote Originally Posted by IceDouTGaLanT View Post
    I would deff look at the coil packs bc thats a pretty good amount of miles on the coil packs and 2 years of boost...yeah I would look at the coil packs one of them might be fried. I may be wrong but dosnt hurt.
  9. #49
    04-10-2005
    NYC
    3,695
    rpn i have the stock coilpacks still from my brithers car when i parted it out. as well as magnecore wires if you want to switch them out as well.
    shoot me a call or a pm and if you want them ill give you a good deal
  10. #50
    04-29-2009
    Holyoke,Massachusettes
    3,600
    yeah the last SOHC valve cover I removed from an 8g was GoldGalant-REBORN's car. It took me about 45 minutes to get all the old pieces of valve cover gasket out of the valve cover because it was stuck, I ened up using a small flathead screw driver and a torch to heat it up.
    on my v6 it took me about 1 1/2 hours to get one out. ended up messing up the valve cover n had to get another. why do they stick so bad? my g is the only ive worked out that had this problem.
    FreakyDeaky
    2kG 6g72/74 5 speed
  11. #51
    back to life=
    16:1 afr is scary-death for a f/i car man. but that's lean, i would be more worried about the fuel system/tuning than ignition at this point. rich will bog & flood & die, but usually not enough to actually hydrolock and cause damage, super lean conditions, however, blow sh*t up on a regular basis...
    love to get an update on what really happened?
  12. #52
    The car is still down, waiting on receiving my new coilpacks. I doubt its a tuneing issue, either fuel or ignition. The car ran great on this current tune for 2+ years with no issues with lean/rich, and just suddenly last month i experienced few backfire's and then this whole stuttering issue happened where car cant be driven. Hopefully its an simple fix *fingers crossed* maybe when you TGC nyc guys stop down for eastcoast mod, you can swing by its 30 mins from my house?
    13 GTR
  13. #53
    08-04-2003
    NY
    4,344
    Ron if there is still a problem with it when mod comes let me know. I will def try to help you out while im down there.
    99' Galant ES
    4G64/63T
    AEM EMS
  14. #54
    Update: Installed new coilpacks + magnacore wires
    Had to replace battery since it drained, thanks optima for the 3yr warranty!
    Started car, AFR=16.0 and sounds like a tractor still. I just dont get it arghh! Would bad fuel cause this problem?
    13 GTR
  15. #55
    08-04-2003
    NY
    4,344
    Ron can you take some video of it, or anything with sound? How does it sound if you rev it a little to lets say like 2,000?
    It could be bad fuel, if you can drain the fuel great, if not, I would go to a speedshop or local track and get like 5 gallons of 100 or 110 and mix it in, that might help it a bit if the old gas has alot of moisture.
    99' Galant ES
    4G64/63T
    AEM EMS
  16. #56
    wait it sounds like a tractor? have you check to see if your sparking on all your plugs cause our engine sounds like a tractor or lawnmower when it runs on 2-3 cylinders when my ecu fried it sound like a lawnmower cause i was only running 2 cylinder cause the black/blue ignition wire from ecu pin 11 was feeding 5v even though the wire is supposed to be a ground check the black/blue and the white blue wires from your coil packs to make sure they are grounding properly if your not sparking on a few if your sparking then check your injectors maybe your only getting fuel to a few cylinders or a bit less in one or 2 causing leaner overall conditions i had one of my injector seals get screwed up on me and my egt skyrocketed. and it wasnt a big leak either.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
  17. #57
    Hey Brian, i will try to get a clip this week. Best i could describe it under 2K is like its on maybe 2-3 cylinders.
    Reikets- Thats sounds just about right to whats going on. I never checked voltage, im guessing a standard volt meter is all i need?
    13 GTR
  18. #58
    06-13-2008
    Bronx, NY
    2,606
    Hope you get your G fixed. Let us know what is going on. Take a video
    SOHC Turbo
  19. #59
    yea if you put the power to the larger wire(power wire) and ground it out to both the other 2 it should read around 11.2-12.whatever XD. make sure the key is in the on position when you do this or it work read anything.if either of them show like a 5.5ish number your prolly having the same problem I did.
    2002
    2.5" tbe
    evo 8 ecu and maf
  20. #60
    Heres the videos requested.
    13 GTR
