Thread: finally decided to do it....5spd swap that is.
Showing results 1 to 20 of 29
    so far heres my parts list
    1- Fidanza flywheel
    2- Act 2100 hd clutch/ 6 puck
    3- 95 manual trans 7g only 80,000 miles
    4- manual pedals from a 96 gs
    5- 2g eclipse short shifter
    6- prothene bushings
    waiting on clutch cable and shifter link rods from B19wheels, am i missing anything or any suggestions are welcome. Also if anyone has an extra manual clutch pedal mounting bracket let me know im missing that.
    Nobody built like u, u desighn ur self.
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
    you will need a 2g manual starter.
    its a 7g trans, why would i need a 2g starter. wouldnt a 7g man starter work.
    5spd swap
    18x9 Works VS
    7g 2g interchangeable, for most pieces
    im more than 100 percent sure it would work. but it is not mentioned on the swap tut. so excuse my ignorance i may be wrong
    thats fine
    5spd swap
    18x9 Works VS
    North Bay...NorCal
    2,552
    Why would you need a pedal bracket? I didnt use one (I dont think) it just bolts to the firewall
    2g starter works, Ive been running one for almost 3 years now.
    you need also:
    Flywheel Bolts
    Master and Slave and SS clutch line
    IDK what bushings youre talking about, but if you mean the shifter and shifter cable bushings, get Dave Symborski kit for the shifter base and brass bushngs (skateboard bearings) for the shifter cables
    anyone got a master and slave cylinder to get rid of pm me.
    5spd swap
    18x9 Works VS
    master and slave with clutch line from B19wheels
    5spd swap
    18x9 Works VS
    parts needed, mounting bracket for shifter and bracket to hold shift cables in place.
    5spd swap
    18x9 Works VS
    i can look for it in the junkard it think they have it
    bro whos doing the swap for you?
    TURBO= in the making.......
    Quote Originally Posted by warren View Post
    thanks
    __________________
    03 Galant
    09 TRD Edition TC RS5.0 #505 of #2000
    just me and a friend are going at it, got the old trans out yesterday
    5spd swap
    18x9 Works VS
    nobady didnt you know my car is standard when it was first made
    got the flywheel and clutch bolts today, also both the brackets that mount on the transmission and before the shifterfor the shift cables. Still looking for the the mounting bracket for the shifter.
    5spd swap
    18x9 Works VS
    ok predat i look for it
    theres a full swap in the yard right now, but its too hot out to do anything
    this heat is killer
    5spd swap
    18x9 Works VS
    its raining bad over here
