Thread: 5speed swap pls help
Showing results 1 to 8 of 8
    Icon4 5speed swap pls help
    i have a 01 galant 4g64 what do i need to swap to a 5speed thanks
    UGH (facepalms)
    Transmission
    clutch
    flywheel
    shifter assembly
    shifter cables
    master cylinder
    slave cylinder
    1996 galant s
    off of what car the 95-96 eclipse
    Doesn't sound like you're ready for this kind of work. Most people (here) read instructions first then ask questions whenever they get stuck on something.
    01-08-2008
    Levittown NY
    2,786
    Quote Originally Posted by G-spot View Post
    x2, 3, 4, 5, 6, 7
    learn about your car first.
    thats why i ask first haha before i mess something up
    Experienced TGC Member
    10-18-2007
    Glen Burnie, MD
    1,314
    Read before you ask. There is a search button and it is very useful hen it comes to this topic.
    Experienced TGC Member run1206's Avatar
    08-15-2006
    Perth Amboy, NJ
    1,558
    look for the 8G Manual Transmission Swap thread, should be right up top in the How to 8G Tutorials List. It should have most major parts listed for the swap. PM him to find out all the other small parts needed for the swap as well. (Either him or DryBear; they may have the manual's COMPLETE list of all parts needed.)
    run1206's Rear Disc Tutorial
