Thread: startup squeal noise. not belt. ?
Showing results 1 to 4 of 4
    TGC Regular starh4x's Avatar
    11-30-2008
    New Zealand. HTOWN
    527
    bought a 7gvr4 195,000kms.
    on startup I get loud squeak about 2 seconds after the engine has started.
    sounds like a belt but its not.
    just changed both ac belt and alternator belt becuse they were worn and there adjusted tight with little no no slack.
    what else could be doing this?
    starter motor not disengaging right away after motor has started?
    dcamacho210
    I had the same problem after changing my belts, they were tight but still squeaked. i just had to loosen and re-tighten the tension pully.
    11-30-2008
    New Zealand. HTOWN
    527
    ok ill readjust both one more time and see what happens
    11-30-2008
    New Zealand. HTOWN
    527
    i was right, its the starter motor. wish it was just a belt
