Thread: Seat Options
Page 2 of 2 FirstFirst 12
Showing results 21 to 26 of 26
    08-18-2004
    Charlotte, NC
    1,029
    Mitsu FTO seats...I wonder if the Toyota Celica(last generation) seats will work.
    1994 GS FYI
    DSM/CSM Manuals
    This is a 7g galant seat in a 3g/8g .
    As you can see 3 of the holes/studs line up. I believe some one mentioned just switching out the lower rail for the correct one. which in this case would be a right 3G/8G eclipse/galant lower rail(driver chair). The reason the hole doesnt line up is the 7g bolt holes are a straight "H" while the 8g top right bolt is shifted in(left) more.
    2g seats fit with a little parts swapping I still need to do something with the plastic shroud by the door though.
    gotta love oem 7g seats. just got rid of my old "sporty" seats and went with oem again
    7g leather and in good shape is pretty rare though yours look excellent, nice find. I spent a few hours screwing around with it mainly just for the heck of it and to show that it is possible.
