Thread: My slowly progressive build thread
Showing results 1 to 20 of 24
    Icon7 DJAKAY's slowly progressive build thread
    Ok, so it's been a while since I've had time to invest in modding, upgrading my G. I made some changes/upgrades, and i'm not stopping here.
    So far, installed list as follows: (pics will be added later)
    Exterior/Interior:
    JDM New style front bumper
    JDM New Style grille (someone cracked it, need to replace)
    JDM Headlights
    JDM Fogs
    JDM Folding Mirrors
    Evo 8 Brembo brake upgrade
    Evo 8 Momo steering wheel
    Evo 8 17" Enkei OEM Wheels
    Black suede door panels/rear panel/headliner
    02 Eclipse black/blue front leather seats
    Flat back/gray painted interior
    Entertainment:
    Custom Car PC: Running Centrafuse 3
    AV/Wifi/Phone/Bluetooth/OBDII/
    2GB DDR3 Memory
    160GB Slim SATA HDD
    Custom 8" Touchscreen
    2 Front Hertz EV165 6.5" Component Speakers
    No Rear Speakers
    Polk Audio 200.4 Amp
    Performance/Misc:
    Injen Short Ram
    NGK Spark Plugs and Wires
    Megan Racing 3G Cat-back
    D2 36-way dampening Racing Coilovers (JM Auto Racing)
    R1 Concepts Slotted/Drilled rotors
    Some things that are in the near future
    JDM Rear bumper w/ side extensions (waiting to be painted and installed)
    Sideskirts (still contemplating)
    ...and here are some of the pictures
    there will be more
    Another project I'm working on:
    6G72 Twin Turbo build collecting information and parts. This will be a long and painful
    project but I'm determined to get it done.
    Feel free to comment, suggest, follow.
    - If you've got nothing nice to say, what the hell is wrong with you!?!
    Can't wait for pics. Your sig gif is amazing XD
    So I assume you're bisexual then? you look like vin diesel..so you must like the cock
    Lol, are you hitting on me?
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Good luck buddy...sounds good and you have so much good info here to help you out
    03-12-2007
    Dallas TEXAS
    2,041
    picsorban haha
    Reserved for pics
    Got the Evo steering wheel installed. It was a real pain in the ass. The Evo hub connector is slightly bigger than the stock,
    So the stock hub connector needs to be cut out and welded instead of mentioned above
    sorry did not take pictures of the welding process, didnt have my camera,
    but here is the end result
    is the airbag functional?
    98 LEGNUM 25-ST & 99 LEGNUM VR4
    CLUB VR4 - The Ultimate Resource
    ^^ i haven't connected the airbag, the connectors are different. but even then it's not definite whether its functional until it deploys in an accident :(
    Update: got brembo brakes installed, with new rotors, new pads, 17" EVO Enkei's with 235/45/17 Sumitomo HTR Z II tires
    need to adjust my front camber
    Awesome dude!
    JDM Headlights
    JDM Fogs
    JDM Folding Mirrors
    4GB DDR3 Memory
    250GB Slim SATA HDD
    2 Front Pioneer Premiere 240W 6.5" Speakers
    2 Rear Pioneer Premiere 260W 6"x9" Speakers
    Boss audio 1200W Amp
    Injen Short Ram
    17x7 Konig Incident running 235/45/17 Tires
    D2 36-way dampening Racing Coilovers (Thank you JM Auto Racing)
    I'm planning to get these Mitsubushi Accessories for myself.
    Good luck on your future projects!
    As for me, I'm planning to get these
    I wanna be a Billionaire... so freakin' bad...
    holy positive camber batman
    if you need help with airbag, stop by my friends shop on Mcdonnald ave. We did this conversion about a month ago with the airbag.
    Haven't been in this thread for a while. gotta update with more picture and videos
    Quote Originally Posted by GOOSEY2099 View Post
    are you talking about major tire on mcdonald ave by any chance?
    ice auto mcdonnald and ave O.
    thanks, ill check it out, you think they can fix my horn too?
    Nice work man. Keep it up.
    The key to Immortality is first living a life worth remembering.
    Tried out the Garmin Mobile PC today. I know it's a very bad quality video but you get the idea.
    time to upgrade my interior lighting
    So today i decided to start wiring up for the K8055 controller
    got my new super bright 12 LED dome light
    They came with variety of disconnects, so i soldered one end for easy replacement
    Also i added the aux wire for the controller
    Also got my beefy power supply M4-ATX and the case.
    The power supply is programmable via USB, start up/shut down delay, min/max voltage, trigger voltage, etc,.
    Here is the pinout:
    [GND] [GND] [USB D+] [USB D-] [ Vcc ]
    [ NC ] [GND] [ AMP ] [PW SW] [PW SW]
    Fabricated my own cable according to pinout
    Installed everything into the new case
    This USB hub fits perfectly inside the case
    the bolts keep it secured
    The case is really small, smaller than i thought.
    Next to come.........
