Thread: Rim and Tire size?
Showing results 1 to 10 of 10
    Rim and Tire size?
    Hey guys I have gone through the fitment post and looked at all the links but I am still new to this and I wanted to make sure I have the right size before I make the purchase.
    The rims I am looking at are
    18 x 7.5 ET 40
    With the following tires
    225/40/18.
    Does this fit without any rolling or cutting of the fenders? When I drop the car on tein spring will there be any issues with rubbing?
    The car is a 2003 LS if that matters.
    Thanks
    Damm just noticed I posted this in the wrong section could a admin move this please.
    Thanks
    04-01-2008
    Tempe, Arizona
    1,996
    those are pretty conservative so they should fit no problem
    blue8g
    yes they'll fit
    I've got 225/40/18's on my G, on Tein S-techs, my rears rub over every small bump, so I have to roll mine, but you may be alright, rims can affect this too.
    So I assume you're bisexual then? you look like vin diesel..so you must like the cock
    Lol, are you hitting on me?
    blue8g
    ^did you see the specs on the wheels? mucho conservative....
    my old wheels were 17x8 +40 with 225's and i only rubbed on full lock
    thanks guys. I will post pics when I get them
    kinda curious if anybody has any pictures to visually see the differance between 235 and 225 tires width, i know its only 10mm but i need to see the difference lol
    Member 6g72lover's Avatar
    09-28-2009
    republic of panama
    366
    dude! mah car have 225/40/18 on pirelli and DRAG wheels dr-18 and dropzone lower springs, no rubb
    thanks man, but do you have a side shot of the rim and tire?
