Thread: My black on black VIP "style" build
Page 13 of 51 FirstFirst ... 39101112131415161723 ... LastLast
Showing results 241 to 260 of 1015
  1. #241
    im mad at myself for showing you those wheels now
  2. #242
    i think you need a 10mm spacer on the rear. lookin good though.
    if the USDM 8g shares the same rear setup as the VR4, then hypothetically, you should be able to fit a 19x10+27 with a 235 on it easily. you would hav to run about -5 degrees camber and pump the guards
  3. #243
    Quote Originally Posted by unclepaulie View Post
    the suspension is different between the USDM 8G and the JDM 8G, both front and rear. the USDM 8G galant is actually more closely related to the 3G eclipse than it is to the JDM galant.
  4. #244
    Needs more low.
    what r u talking about?
  5. #245
    does the usdm rear hav an upper A arm and a vertical banana arm? kinda shaped like (
  6. #246
    Yes. The backspacing should clear the suspension. Not sure however if -5 degrees of camber will still allow the wheel and tire combo to clear the rear knuckle and C/arm though?
  7. #247
    That looks awesome Ricky!!!!!!!
  8. #248
    05-03-2007
    Socal/Central Coast
    3,803
    man that is reallllllly low. I can't imagine running SVR-4 sideskirts on that haha. Looks good though
  9. #249
    it's air ride so it's only low when it's down all the way... it's not gonna be driven around at that height all the time.
  10. #250
    05-03-2007
    Socal/Central Coast
    3,803
    yeah I figured as much. That would be impossible haha. Imagine going down the 405 even an inch higher than that.. holy shit that would suck
  11. #251
    I'd drive that low :D
  12. #252
    03-12-2007
    Dallas TEXAS
    2,041
    i just washed the car but i cant find my f@#king camera theres no telling where my daughter put it. i just hope not the toilet :(
    me too if i could get away with it. just a little more hacking
    its bouncy as hell i cant get a nice psi setting for the front
    it should be fun
    Quote Originally Posted by greddy View Post
    thanks man
    Quote Originally Posted by VIPtint View Post
    aaaawwww come on man these wheels are so on point
    i think he means it needs to be lower lol
  13. #253
    should do, i was running -5 degrees camber for a while, it worked fine
    damn awd! otherwise id be running staggered wheels
  14. #254
    u can still run staggered faces/offsets though right?... as long as you keep the width and tires the same? in that case you could run hi disk up front and lo disk in the rear w/ lower offset and it would "look" staggered but your 4WD would not know the difference since the tires and wheel widths would be the same front and rear.
  15. #255
    yeah your right, but to that id need to fork out a lot of cash...cash i dont hav lol
    some custom 3PC wheels would be awesome
    we're goin a bit OT lol, back to ricky's 8G
  16. #256
    03-12-2007
    Dallas TEXAS
    2,041
    ok now regarding all of the hacking i have to do.......
    just a few more shots of the fitment
    the radio trim is almost done, now im going to have to find somewhere to get it dipped or airbrushed
    put the side skirts back on to fap right quick and see what i needed to glass 2maro
    then i bust out the foam
    2maros going to be a hell of a good fiberglass day
  17. #257
    fog lights are a must, not vr4 ones obviously
  18. #258
    Are the wheels sitting on the air struts?
  19. #259
    05-03-2007
    Socal/Central Coast
    3,803
    G-spot's old side skirt I presume? And that bumper could actually work pretty well with this theme (IMO)
  20. #260
    I need to see this project in person (and take pictures with a better camera )
Tags for this Thread
