Thread: VR4 Wannabe
Showing results 1 to 9 of 9
    Galant ST_EA5A
    VR4 Wannabe
    I'm sorry if my language so bad. B'cos i'm a tuner not a teacher.
    This is first Project for my workshop to be done.
    For the first time, we'll start from here.
    Halfcut VR4 engine, wiring, ecu, wiring, and 4wd.
    This is the car. Galant ST EA 5 A with spec :
    V6 - 24 valve, 2400 cc, SOHC, 165 hp, and FFWD
    Want to Upgrade to VR4 stock engine.
    First step. Making internal engine very clean. It would be better for tuning engine.
    Next step... Will be updated as soon as possible.
    03-12-2007
    Dallas TEXAS
    2,041
    is that the whole front end off of a VR-4 for your 6A13TT swap?
    Lucky! if I had that I would be doing my sebring right about now!
    02 Diamante VRX 5spd swapped
    90 Galant GSX 5spd EvoSpec 4G63 swapped
    01 Sebring GT Coupe (6G75 Powered)(sold)
    I have found those from clips from $1500 to $2500. You just have to look for them. This is why When i first got to this site so long ago i use to ask about the swap and was told that it couldnt happen.
    Good luck with it.
    Galant ST_EA5A
    Yaps. full VR4 swap from headlamp to tail light....
    03-12-2007
    Dallas TEXAS
    2,041
    Quote Originally Posted by 2002BlackDragon View Post
    Good luck with it.
    i thought those engines just fit right in to his spec galant
    good luck with your build
    Galant ST_EA5A
    Quote Originally Posted by Bring350GT View Post
    Thanks bro. i'll set up as a stock engine first. Hopefully i can get upgradable part to my VR4.
    Good luck with it.
    Let see what we can do....
    blue8g
    Quote Originally Posted by Galant ST_EA5A View Post
    Dragon is talking about the US spec Galants
    How are you converting from FWD to AWD?
    Drive, Dream, Drift.
    Drift ALL DAY
