So, I'm guessing we'd need to know how the remote system works to know how to interface it with that kit.
Someone correct me if I'm wrong, but the negative trigger wire means that we switch the trunk release by giving that wire a path to ground (i.e. the car body). If your remote system has a relay switch of some kind, you'll want to wire it up so it will ground the negative trigger wire on the trunk release control. That should pop the trunk with the remote.
On a side note, are you just planning to put the button where the current release is?
