Thread: Front end shake/vibration
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 48
    I recently lowered my car 2" in the front and 1.5" in the back and had a problem with the car shaking when i accelerate. I looked under there but i couldn't see any problems. At one point when i was lowering it i thought i tore the boot, but i double checked and it seemed to be alright. Anything i could have overlooked?
    I expected the Rocky Mountains to be a little rockier than this.
    04-29-2009
    Holyoke,Massachusettes
    3,600
    your axles are binding i had the same problem with mine had to replace both n raise it back up
    FreakyDeaky
    2kG 6g72/74 5 speed
    11-13-2007
    -OKC-
    3,970
    +1^^^
    04-29-2009
    3,600
    hey raz whats up you havent posted after me in a while lol. again the sig is sick lol
    FreakyDeaky
    2kG 6g72/74 5 speed
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by Corey2000Galant View Post
    Been busy dude, thanks.
    Lowered G's especially V6's get axle wobble when lowered more than 2".
    I get wobble under 20 mph though, it is barely noticeable.
    Jigz-TGCIL Sosick Motorsports
    05-03-2007
    Socal/Central Coast
    3,803
    TGC Regular bsilver23's Avatar
    04-06-2009
    Mequon, Wisconsin
    584
    ^^ yup the washers cure it
    Bryan - TGCWI - 6g72 5 speed
    http://www.cardomain.com/ride/3376567
    ah thanks man, I'll probably tackle that today :)
    Today i tackled taking my front end suspension apart..put the washers on and i still feel the vibration. It's not nearly as bad but its still there. Any ideas on what else this could be? Also was this washer solution supposed to completely fix the binding or help slow the binding?
    04-29-2009
    3,600
    Quote Originally Posted by Stepsascend View Post
    Well I have the same issue with mine I did the axle mod as well and I still vibrate I'm guessing my mounts could be bad and its putting the engine at a bad position n making the axles bind. So I'm gonna change my mounts again n see if that takes care of the issue. You should check your mounts!!.
    FreakyDeaky
    2kG 6g72/74 5 speed
    if it were the engine mounts wouldn't it have been vibrating before the drop? Everything looked good when I put the washers on. I'm thinking my tie rods but i highly doubt it.
    04-29-2009
    3,600
    Not really but check your mounts anyways I know my front one shit the bed. I gotta check the rest of them. My tie rods are good Im just guessing that it is the mounts a friend of mine said it could be an issue so just double check your mounts.
    FreakyDeaky
    2kG 6g72/74 5 speed
    alright man thanks ill take a look tomorrow
    Alright..I've tried the washers and they didn't work. I Replaced my engine mount inserts with prothane inserts..I took the washers out because since I changed my mounts and figured that wasn't the problem. Then I put bigger thicker washers in and I'm still getting wobble at higher rpms. It's only when I really hit the gas...any new ideas or suggestions?
    04-06-2009
    Mequon, Wisconsin
    584
    same thing still happens to me too and i hate it. if it wouldnt vibrate so much when punching it, the car would seem even faster and would just make the overall feel better and safer feeling.
    lol that's exactly how I feel. I don't want to drive like a grandpa anymore I want to get this figured out.
    Have you tried getting your tires balanced recently? Sometimes mine wobble at low speeds when my tires need to be balanced. Also, I had some wobble especially when taking off while taking a turn, and it turned out one of my axle boots has busted, and after changing that it went away.
    04-06-2009
    Mequon, Wisconsin
    584
    Quote Originally Posted by tamim13 View Post
    thats a good idea and makes sense acutally. another weird thing about my car is the loose steering. sometimes ill be driving and the steering wheel will be turned about 4 inches even tho im going straight, then when i come to a stop it like resets and then drives straight lol. i have a feeling that may be with my balancing/aligning
    06-13-2008
    Bronx, NY
    2,606
    Do a wheel alignment and a tires balance. Also go under the car and double check your control arms bushing and stabilizer links.
    SOHC Turbo
