Thread: Fluidyne Radiator
Showing results 1 to 2 of 2
    GalantSpeed
    Fluidyne Radiator
    I was told by some people that the 95-99 eclipse have the same exact radiator as the 7g. is this true? b/c i'm wanting to buy a fluidyne radiator soon for me 7g, the only difference i have noticed from the 2g eclipse and the 7g is the 2g doesn't have a radiator cap where ours is. they have a hose that goes to the thermostat or in the area of it.
    http://www.fluidyne.com/pl_hpimports.html
    01-10-2003
    BROOKLYN nYC
    1,570
    I believe the overall dimensions are somewhat the same, it should fit without problem. The 2g fill coolant at the thermostat housing not the radiator. When I do the headswap I can fill either at the radiator or the thermostat! lol
    But I doubt you will have any problem with it. Assuming the mounting locations are the same, otherwise some modification will be needed to get that sucker in.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
