Thread: Looking at drop need advice
Showing results 1 to 20 of 31
    03silver8g
    I have 18's with a 225/40 size tire. I am looking at some Meagan springs that drop it about 2 inches all around, my rear sags because i think my struts are blown but im not sure. So what do you guys suggest i do? Sorry i prob could have searched this but i need to know asap...
    Thanks Guys
    well get new struts 1st or save some money for coilovers
    i personally think 18s and meagans might be too much. get teins
    or u can just use search button then sitting and waiting for answers
    i know a guy that saw a guy that knew a guy that once passed by a car that had been painted. Ill ask him tomorrow after consulting my magic ball to determine WHERE YOU LIVE in proximity to a paint shop NEAR WHERE YOU LIVE..................
    Just save up for adjustable coilovers. Can't go wrong there!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    05-02-2008
    Hacienda Heights, CA
    3,014
    a Cali member had 18's and Megan Springs and his drop is prefect IMO for springs. he has like a 1 finger gap all around. heres the best pic i can find. its the white one:
    05-02-2008
    3,014
    heres his progress thread so you can see more pics: https://www.thegalantcenter.org/showthread.php?t=37773
    Member krow's Avatar
    01-22-2009
    Baton Rouge, La
    325
    Quote Originally Posted by E_Emerson88 View Post
    I don't think Megan Springs gave someone a 1 finger gap all the way around. The front of a stock Galant has more than a 4" gap and Megan's have a 2" drop. I have KSports with a 3" drop and still don't have a 1 finger gap.
    I have 1 finger drop w/ progress springs but I do agree you'll be more satisfied with coilovers over lowering springs
    we just tell you i got problems with my lowering springs i get no drop
    03silver8g
    i think it looks great. you guys think my tires would rub there 225/40R18
    Quote Originally Posted by 03silver8g View Post
    no you should be fine i got megans on gr2s and the same size tire,just get a camber kit for the back,maybe the front,i only needed a camber kit on the front right
    03silver8g
    Quote Originally Posted by 8g831 View Post
    what about with people in back does it rub?? im gonna be using my stock struts
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    If it rubs, then you'll need to roll your fenders.
    4g64T 5spd
    03silver8g
    and then it should be fine? ha ha man thanks guys im pretty new to all this
    03silver8g
    @ OMEGO PHX are you dropped? what size rims you have on your G?
    Mine has never rubbed and I've had 3 people in the back,if it does rub just roll ur fenders
    05-03-2009
    1,465
    Yeah I'm dropped but I'm a clear example of what not to do lol, I dropped my G before finding this site and well I have garbage DZ sport lowering springs that are bouncy as shit and I'm still with oem struts that are starting to blow, and my rims are 20x7.5 +42 225/35 tires, rear fenders were cut a little but need more cutting.
    I would like to install some D2 coilovers but can't make up my mind on spending $900+ on them.
    @OP Whats the offset and width of your wheels? Are you rubbing on any way? at full lock?, if you drop you'll most likely have to roll your rear fenders. The offset of the wheels and the width are the factors that can affect if you rub or not, since your tire size is proven to work.
    4g64T 5spd
    03silver8g
    the offset is 45. and it almost rubs with 2 people in the back. I think i am going to do it and i will put pics up asap
    03silver8g
    uhm.. what exactly is a camber kit??
    05-03-2009
    1,465
    When you drop your g the rear wheels will get negative camber, when look from behind your tires will look like this / \ , this is negative camber and since this will eat your tires on the inside so you may want to get a camber kit to correct this and make them straight again l l
    4g64T 5spd
    03silver8g
    would a 4 wheel alignment fix it?? or would i for sure need a camber kit?
