Thread: just wondering
Showing results 1 to 3 of 3
    just wondering
    im just wondering guys,,they said that the 04-06 lancer ralliart have the same engine for 9g's i4,,,does it mean that some engine and drivetrain parts will fit perfectly or not,,need some inputs
    this are the part i really wanna buy for my g
    camshaft
    http://www.roadracemotorsports.com/s...c46b2310fe0995
    port and polished head
    flywheel
    timing box
    turbo kit
    port and polished intake manifold
    thank you so much...
    It is the same engine, but can't say the details are the same. It will matter if the engines are installed the same way in the two cars to be close to compatible. Based on looking at a couple pictures, the engines are installed the same way (exhaust manifold in front, intake in the rear). If I were you though, I'd send a message to RRM and ask them, or even the C3G, or C4G guys.
    thanks dave..
