missing power stering fluid?
Last time since I was parking I noticed that when I turn wheel all the way either way car starts to make weird noise , only happens when I turn wheel all the way
__________________
-Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
-Mitsubishi Galant LS 1994 a/t [ SOLD ]
I would check the tension on the belts, check the fluid also, if its full and the belts are not loose i wouldn't worry too much. Most every car I've driven do the same thing with the exception of some cars less than 5 years old. maybe its just average wear?
Gotta be a power steering issue. Now was the car sitting for a length of time without moving? I noticed mine was making a noise as well...but the car had been sitting for a while. I drove it for a bit and it worked itself out. But I agree with Jake, check the fluids, next make sure the power steering pump is ok, then the belts. Good Luck
