Thread: resistor pack for 450cc injectors
Showing results 1 to 14 of 14
    I am adding an EVO 8 ECU to my 02 G. Since I'm adding the evo ecu will I have to use the resistor pack for the 450cc Injectors or would I be able to tune around them with the ecu?
    10-18-2007
    Glen Burnie, MD
    1,314
    Read man read, there are ways around having to use a resistor pack.
    Quote Originally Posted by WhiteGalant View Post
    So, ummm, Is that a yes? A no?
    10-18-2007
    Glen Burnie, MD
    1,314
    Umm that would be a "search" haha. Theres a lot more to this then you think. Are you still an automatic? Do you plan on running dual ecu's?
    yes, dual, evo8 and my stock. I have the resister pack and could just solder it in, but If I don't need it I'd rather not waste the time on it.
    from what i understand and i could be wrong you can run any injectors w/ any ecu as long as you wire the injectors correctly 450 should be running on a resistor pack regardless of the ecu.
    08-15-2006
    Perth Amboy, NJ
    1,558
    get the WRX 440cc blue top injectors. I have them in my car (non-turbo at the moment) and they run fine.
    run1206's Rear Disc Tutorial
    Member allrice4g64's Avatar
    02-08-2010
    hager city, wisconsin
    330
    the 450cc injectors must have a resistor pack because they are a low independance injector versus ur stock injector which is a high independance injector. it only really takes about half hour to install the resistor pack and all the wiring.
    What injectors should I buy so I don't have to splice?
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by CORKDOG View Post
    WRX 440cc injectors, I said this before!!
    They're High Impedance, so no need for a resistor pack.
    Quote Originally Posted by run1206 View Post
    if you want to buy higher cc
    http://www.deatschwerks.com/catalog/...roducts_id=128
    08-15-2006
    Perth Amboy, NJ
    1,558
    Too expensive, go to clubWRX.net, you can get them for 100 shipped there.
