Thread: vacuum diagrams for dohc swap
Showing results 1 to 6 of 6
    Im doing the kia swap and have the evo manifold and i am using the stock tb for right now but i was wondering if anyone has a diagram so i can hook this up correctly the first time. thanks
    08-04-2003
    NY
    4,344
    There shouldnt be any more/less vacuum lines to hook up. When you disconnect your vacuum hoses from the engine, just label each hose as to where it goes. It shoudlnt be too hard, there re only like 5 or 6 hoses.
    99' Galant ES
    4G64/63T
    AEM EMS
    05-03-2007
    Socal/Central Coast
    3,803
    Also, under the hood there's a vacuum diagram for the stock stuff. Basically what you need to do is just run the lines exactly the same or to similar locations on the Evo manifold
    06-13-2008
    Bronx, NY
    2,606
    Bro we more information about what diagram you want. What year is your car?
    SOHC Turbo
    06-13-2008
    Bronx, NY
    2,606
    Ok I will be nice. Galant
    2005 Mitsubishi Lancer Evolution L4-2.0L DOHC Turbo:
    SOHC Turbo
    thanks thats all I needed to see its really just where the sensors are in order to reroute some of the lines
