Thread: Injectors.....
Showing results 1 to 4 of 4
    Injectors.....
    I've finished my head swap to the hyundai head and have a quick question.. for the injectors (since i am also running a turbo) does anyone know of any higher flow injectors that fit the sonata IM? since its similar to the evo one does anyone know if evo injectors would do the trick? any input would help thanks.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
    10-05-2008
    Grand Rapids Michigan
    1,141
    If i am not mistaken the WRX 440cc's will plug right in, as far as spacing them out I'm not sure, but i am sure this might be plastered all over TGC
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by johnygezony View Post
    correct. I'm running WRX 440cc injectors and no problems thus far. Just scale them and you're good to go (no need for spacers either).
    run1206's Rear Disc Tutorial
    main problem with wrx injectors
    I cant use the same ones we normally use im using the sonata intake, rail and injectors for them moment. Our rail and injectors dont work on the sonata intake.
    *edit* i may be able to "make" them work somehow ill take a look tomorrow but when i was assembling it all i remember them not fitting
    2002
    2.5" tbe
    evo 8 ecu and maf
