Thread: Suspension Setup
Showing results 1 to 11 of 11
    Suspension Setup
    I still haven't purchased my springs yet so I'll ask a couple more Qs before I do. I know Tein has two different kits, one specifically for the V6 model (I have a I4). Is there a reason Megan or Progress don't do the same? I want to do a 2" drop in the front and under 2" in the rear so I was looking at the Megan Springs. Progress only make 3g springs which work but will they look the same in height on our rides? Here's my ride, and I'm not doing any crazy wheel setup. Just 15" 3g rims and stock tire size. What do you all think?
    If it ain't broke, i'm still fixin' it.
    05-02-2008
    Hacienda Heights, CA
    3,014
    if you want more of a drop get Megans. But since your going so low i suggest you get KYB AGX's. If you dont wat so much of a drop go with Tien's. You can get away with normal GR-2's since the drop wouldnt be that much. Answer your question? pretty much different brands, more or less drop lol
    Quote Originally Posted by IVORY_G View Post
    never pull out, always squeeze inside! LOL!
    05-03-2007
    Socal/Central Coast
    3,803
    Progress makes a set for the 8G.. or at least they used to. I'm running Progress springs. I believe they are a 2.0+ inch drop all around. I think the 3G set is less of a drop.
    oops not 2.0+ all around, but 2.2 up front and 1.8 in the back
    http://www.wesellcarparts.com/store/...idproduct=4400
    I was looking for the KYB AGXs too. At a 2" drop, could I get away with not getting a camber kit or not?
    05-02-2008
    3,014
    it would be suggested when you lower your car to get your camber back to factory settings. i have coilovers but im not running a camber kit.
    u will most likely need to get a camber kit for the rear if u drop over 1.75".
    Ok. What's a good kit to get? I was looking on Andy's auto sport, JDM Hub and Import Car Parts Plus. I'll just do both front and rear.
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by RayDub View Post
    Ingalls kits are used all over our community, and I've heard of eibach too.
    4g64T 5spd
    does ingalls make a specific rear kit for the 8g or am I going to have to look for it under the 3g?
    05-03-2009
    1,465
    Quote Originally Posted by Armageddon Sunset View Post
    On ImportCarPartsPlus its under the 3g:
    http://www.importcarpartsplus.com/3g...ion.htm#Camber Kits
    4g64T 5spd
    Ingalls makes 3 kits for 8Gs
    1st: is a washer set. Cheap but hard to configure if your a noob at suspension
    2nd: is a bracket kits with -1/+1 camber adjustment. this is good if you just get springs to lower car
    3rd: is a bracket kit with -3/+3 camber adjustment, this kit is best if you get a coilover/damper set up an drop the car
