would like to know as well...
Ok TGC lets do some thinking here. I have all the parts for the outlander mani swap. I have the mani and the TB from the outlander. Here is the question does the tb from the outlander bigger or the same as the V6. I know that the tb of the diamante v6 is a little bigger than the galant v6. Should I keep the tb from the outlander or get a v6 tb? will it bolt on to the outlander mani? any Sensors issue? Does anyone have any of these settup
Thomas R aka Valpen
CEO & Eventmanager
Mitsubishi Club Sweden
Former New yorker....
94-10 60th Ave
113 73 Elmhurst, NY
School PS13 - then moved to Europe
In not sure about tb size, but I have a v6 and I swapped
for diamante mani and used my stock tb, it bolted on, but the inlet size of my tb
is smaller than the inlet of mani. Everything else bolted on, except the egr
pipe coming from exhaust. It's just a little short and off to the side, so it doesn't
reach the mani. So I had to delete egr completely, now I get a CEL on, but no noticable
performance issues. The is also a thread on the swap in the "how to" section
look it up, a lit of useful information.
- If you've got nothing nice to say, what the hell is wrong with you!?!
outlander tb same size as the galant i4 tb?
i have the outlander manifold in the galant now, it came off an i4 non mivec engine. never found out if they share the same size TB as the i4 galants crappy one bolted to the crappy stock (black) manifold
Yeah, the outlander tb size looks the same as the galant since they both I4. I think i'm wrong anyone has an idea.
since you're going to be swapping anyway, why don't you just pull both the 8G I4 TB and the Outlander TB and measure them? then we'll have a definitive answer.
And yes, being that an I4 manifold bolts to an I4 TB, and a V6 TB fits on the I4 manifold, and an I4 TB fits on the Outlander manifold, the V6 TB will bolt up to the Outlander manifold
Agree with beam514
The 03 outlander TB is alil bigger than the I4 TB...The outlander TB is 60mm and the Diamente is 65mm. You can bolt the v6 TB to the outlander or to the I4 intake manifold. Their is a thread on how to do this swap and everything your going to need, and also make sure you have extra hoses or go to pep boys and get extra hoses from them cuz their is one that dosnt reach.
To answer you question: Outlander and v6 Galant have the same size TB
Link: https://www.thegalantcenter.org/showthread.php?t=39355
Also this is for people that are 5 speed and turbocharged or just 5 speed...not sure if anybody knows but the Evo 8 TB fits the 4g64 intake manifold. Just simple re-wiring here and there thats all. I need to go though my notes again for I can give you guys the wiring for the connector to the TPS. The only thing Im not sure if its a good idea for people running stock G intake manifold since the Evo TB is I believe 63 or 64mm in size and the G stock TB and intake amifold is alot smaller. Might be better with the outlander intake manifold but I could be wrong, but If it was me I would throw it on the 03 outlander intake manifold.
Thanks bro, I have the outlander mani, i will get the diamante tb because is bigger. I just wanted to make sure that the v6 diamante tb fix the outlander mani. I will make sure that tbps is from a diamante. from stock tb to a diamante 65mm opening is a big inprovement. I just will have to sell back the outlander tb.
Remember that the IAC on the 6g74 TB connector is different and bigger than the Gs' stock connector. So you will have to find a junk yard or something and steal the connector off of a 6g74 motor and wire it up to your stock harness.lol Goodluck man let me know how it goes.
I also believe two of the wires need to be switched around...???hmmmm you might have to research that one just incase.
You need the pigtail for the 6G74 IAC. I don't think you have to switch any other wires around, just splice the new pigtail onto where you old pigtail used to be, with the pins in the same places (for the V6 at least).
I would say just run the Outlander TB for the time being if it's really 60mm. The 65mm isn't that much of an upgrade at this point, or at least not worth the trouble you might have to go through
i was running outlander intake mani with outlander tb the outlander tb is bigger its all plug and play with the exception of switching the 2 outer wires of the tps sensor because its on the opposite side of the tb so it turns in the reverse direction. if your running a cold air you can hear a big difference in the higher rpm's sounds mean. P.S. i have all my 4cyl stuff for sale going V6
i purchased a v6 g my plans are to swap out frames and go 6g74 swap with a 5 speed i have mostly everything just missing a few little things which i ordered from the dealer may be in 2 ti 3 weeks my g will be up and running
hey. look guys i found my answer thanx for the info
i plan on doing this swap as well since mine is cracked and i alrdy have the v6 TB
whos to say i wont get the full assy but its good to kno i can still use the 6g72 TB if it dont come with a TB same with the injectors
search and u shal recieve
https://www.thegalantcenter.org/show...outlander+swap
lmao at this too
