Thread: Hifonics Amps Question
Showing results 1 to 20 of 34
    I'm jus wondering if the hifonics are rele as powerful as they say...bcuz if so i want one..but somethin tells me there jus not what they say
    Does anyone here have one or had? Say a Brutus BXI-1208D? 1,200w RMS @ 1 ohm?
    Maybe any of the other ones too?
    2001 Mitsubishi Galant-Totalled..=(
    1987 Cheverolet IROC-Z Camaro-TPI 350
    1989 Nissan 240sx-built SOHC-Trade for Honda
    1999 civic Hatch B20vtec- current
    Lookn for galant to build. .
    The Hifonics Brutus line is what it is hyped up to be in my opinion. Probably the only Hifonics I'd be buying. Buy a cleaner amplifier for the fronts, midrange, and midbass drivers.
    04-08-2010
    Springfield, Mass
    1,225
    they are good my bro has one with 2,000 wtts
    Hmmm..alright..Well im running an MTX on my rear an front speakers..but my REfurbished MTX bass amp blew so im selling my kickers, an Jus bought 2 Type R 12's an lookn for a good amp for em...Any suggestions for those??
    Also i think i read somewhere on sonic electronix that Hifonics arent CEA-complaint rated so i was 'Iffy
    04-08-2010
    Springfield, Mass
    1,225
    just get the hifonics
    09-25-2006
    Central, Cali
    1,145
    i have 2 12 type r if i remember correctly i think they run at 850 rms so u wanna find a amp that will give u no more than 800 rms at 2 ohms x2 right now im only pushing at 300 watts each and they sound amazing ive gotten alot of compliments already
    03 I4
    Alright, Ill prolly try the BXI-1610D then. Thanks guys!
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by jimmy_o2 View Post
    2nd Gen Type R's 12" (the ones with the R in the center of the cone factory specs is 500w RMS, 3rd Gen Type R's (Little R in the Bottom of the cone specs say to take 600w RMS, They are known to take maybe 750w RMS each without a problem but that depends on your box etc., For 2 12" Type R's I would recommend the MB Quart DSC 1500.1 if yours are 4ohm DVC, its known to do rated. I recommend you doing a google search on the amps or asking at a car audio forum.
    4g64T 5spd
    first you need to know of your running your 12's on solo amps or split bridging(1amp 2 speakers) and does you box have two seperate wire panels. are you using an upgraded secondary battery and or alternator, any caps on the lines what gauge wires what brand wires(yes it makes a diff)-(diff brands use diff strand counts) equalizer or sound. alpine 12 R's pass through bottom end mid bass up to middle end Low Bass so you might want to look into a non monoblock bass amp and put high freq filters on the line.
    Brutus BXI-1208D
    Type: Mono Block
    1-Ohm Power Rating 1x1200
    2-Ohm Power Rating 1x900
    the 12 R's at 2x2ohm bridgable to 1ohm and 4x4ohmsbridgable to 2ohms are both rated at
    SPECIFICATIONS
    Power Handling
    CEA-2031 Power Rating: 600 Watts
    Power Range: 600 - 1800 Watts
    RMS Power Handling: 600 Watts
    Peak Power Handling: 1800 Watts
    this means you putting 300 more rated power at all times in 2ohm mode and 600more at 1ohm mode
    you cant run either speaker at 4ohms with the brutus amp or youll blow the amp and speakers. if you want help putting a set up together let me know and we can design one based off your budget
    Quote Originally Posted by The_fresh_Galant View Post
    Don't worry about the amplifiers you buy being CEA complaint, that is industry fluff.
    03-12-2007
    Dallas TEXAS
    2,041
    i ran a 1208d for years w/ no problems (although my electrical system was slightly upgraded so it got 14.2-12.6 volts at all times )
    thanks for more replys guys.
    I kno how to wire em, there dual 2 ohms. I'll run em 1 ohm seperate channel on a hifoniccs.
    And all my electricals are upgraded too.
    Also Ricky, Were you running type R's?
    Brutus BXI-1208D
    Type: Mono Block
    SPECIFICATIONS
    Power Handling
    I have the 2nd Gen. Dual 2 ohm. Ill be Replacing my 4 gauge to 0 gauge. I've decided only one amp. I have a 140 amp H.O.A. Also a 3 farad Cap. I also have a Clarion E.Q.
    Now im debating between MTX 1000XD, Hifonics BXI-1210, or BXI-1610???
    I have a 140 amp [H.O.A.]<-------define that please...
    05-03-2009
    1,465
    High Output Alternator
    4g64T 5spd
    03-12-2007
    Dallas TEXAS
    2,041
    no i was running 2 fosgate 15s
    Oh Ok Ricky...... So Would most agree that the BXI-1210d will power them pretty much perfect in a ported box???
    03-12-2007
    Dallas TEXAS
    2,041
    ok so i typed out a big lone explanation for you but i fell asleep and lost it lol
    so heres the short version
    with your dual 2 ohm speakers you only have two options of wiring .5 or 2 ohms
    the hifonics amp will do 900 @2ohms so that would be 450 to each sub witch is decent you wont have to worry about blowing your subs
    also at 2 ohms your amp will run cooler longer and have better efficiency
    there are amps that do full power @2 ohms but they are not in the price range of the hifonics
    also a class d amp or mono block amp only has one channel (i know hifonics has two sets of speaker outputs but they are connected inside still making one channel)
    hyfonics is one of the best bangs for your buck it is all how you wire it and what kind of subs you are running. running @ 2ohm's with a pair of dual voice coil subs is one way to get the most power out of your amp. i have hyfonics amp on 2 15" solobaric L7's i set off car alarms all day long cant even turn it up all the way i hurts my ears
    [/COLOR]
    You'd actually have .5ohm, 2ohm, and 8ohm.
    http://www.the12volt.com/caraudio/wo...2&I=22#results
    You could even have a 4ohm load with a two channel bridged amplifier.
