You should be fine getting those. They might require a bit of work for fitment into your car and those fogs may take different bulbs but everything should work out for you after a bit of research for the bulb type. I have 3 hid kits on my car =) No extra power supply needed.
If you put the hids in non projecting headlights or fogs you'll want to use 35w ballasts which will actually use less power than original bulbs. Good luck man!
