Thread: Throttle body swap question
Showing results 1 to 11 of 11
    did some searching... about v6 intake throttle body vs I4....v6 is 60-65mm and the i4 is less.....
    WHen you guys are talking about the "mm" 60mm throttle body what are you guys measuring the diamter of the throttle body connecting to the intake tubing???
    cuzz i got a 70mm throttle body from a member here and its the same size of my current throttle body i have on my i4....
    its either i have a upgraded throttle body on my galant all this time or the dude just sold me a i4 throttle body.......
    sorry no pictures just my fustration
    like always thanks in advance and always appricate help/input
    wise up or stand down
    Pic above is a Diamante TB and I think that is how you measure it. The stock I4 TB is 54mm, I think.
    05-03-2007
    Socal/Central Coast
    3,803
    mmm I think it should be the inside diameter of the opening on the TB that connects to the manifold
    EDIT: you know I'm really not sure lol
    THanks for the fast replies guys... thanks conjee that pic looks like a v6 throttle body insepecting the i4 throttle body it has 70mm diameter where it connects to intake tubing but it "bottle necks" going in... meaning its not 70 mm all the way through... cuzz if i meausred the inside it is alot smaller......should i measure the diameter where the things flips open???
    I would think the easiest way to determine the mm of the tb is to measure the butterfly itself since it must fit into the narrowest part of the throttle body
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    70mm??? Whats the TB from? What motor is it from? You should measure the outside and the inside butterfly diameter.
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by jamesgalant View Post
    Galant 6G72 V6 = 60mm
    Diamante 6G74 V6 = 65mm
    the one he posted is a Diamante TB
    as for the true "size", I think you should measure the smallest inner diameter, because that is what is going to restrict airflow a lot. It might just be the diameter of the butterfly valve
    thanks for the help guys....ur expertise is always appreciated...just measured the throttle body its an I4...........70mm is the intake tubing but at the butterfly valve is a whooping 54mm.....so in the end im left with 1 galant and two I4 throttle bodies....COOL...if any one needs a I4 throttle body lemme know....Lesson learned...
    12-02-2008
    1,263
    I have a 6g74 TB if your looking for one.
    06-13-2008
    Bronx, NY
    2,606
    I would love to have one for my outlander mani.. PM me for a price. Thats the 65mm(diamante) right?
    SOHC Turbo
    12-02-2008
    1,263
    PM sent
