Thread: 8G 5 speed hyundai sonata swap.
Showing results 21 to 40 of 46
    like what? trannys been in the car for almost 2 years running fine. About to swap in my second tranny in the spring since i experimented/learned on this one. Everything there is to know is stated in the first post. The rest can be ignored.
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by Exhaust power View Post
    Okay cool. I'm just exploring options for the future. You never know with the auto
    -Andrew
    can i get away with using a eclipse shifter or a evo shifter ? and what about the cables? can i also use 3g cables?
    Evo 8 Head, BC 288/288 BC Springs & Retainers, Weisco Pistons and Eagle Rods 2.4 (Comperssion 9.5:1) ARP Headstuds and Mainstuds, Cosmetic Headgasket, New Clevite Bearings all around, Evo 8 Oil Pump, English Racing water pump, Gates Racing Timing belt, Findanza Adjustable cams, 2 255 walboro pumps, RC 1000s, AEM Rail, and 5 Speed swapped, powered by a 6262 T3 w/ .82 A/R.. WILL MY TRANNY HOLD THIS? Lets wait and see :)
    Im also interested in this swap, because looking at the prices out here i can buy that transmission for 475 on car-part.com
    Quote Originally Posted by Laidback8g View Post
    The floor shifter wont hold the sonatas cables. Im not 100% if the eclipse cable is long enough or too long etc to mount to the tranny and back. I would experiment but im done with experimenting lol
    Quote Originally Posted by DTP View Post
    True
    One tool you need to use a lot is a disc grinder of some sort
    Question. I recall reading on another forum about this same swap and it stated that the shifting is different. It is push style intsead of pull or vice versa. So as i understand it 2nd is in 1st and 1st is in 2nd and so fourth.
    07-02-2011
    South Florida, by the beach
    1,076
    What? push or pull is how the Throw Out Bearing and Pressure Plate interact.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    thats why he turned the TOB rod counter clockwise to address this issue
    aaahhhhhh. Thats what i thought but then i read this....http://www.club3g.com/forum/3g-eclip...ternative.html
    VTECH Killer is talking about a kit to convert. I just wanted to make sure i was understanding all of this.
    Every thing on that 3g forum is speculation. Yes it is a pull style clutch thats it. If your taking all of the required manual parts off a sonata and onto a galant why would the gears be in a different arrangement? virtually nothing changes it shifts and drives like a convectional standard. I made this thread cause i actually installed it any other threads might throw you off.
    The things I wonder about with using the Sonata transmission are the availability of poly motor mount inserts and a decent clutch. If somebody were to do this swap and later on decide to turbo their car, without access to those 2 items would be banging their head against a brick wall.
    Tiburon 2.7, the sonata 2.7 and G4JS share the same clutch as i see in my searches. So finding a good/strong clutch shouldnt be hard. The transmission mount is a great deal bigger then mitsu's but if needed im sure a urethane one could be custom @ low cost.
    And for a lsd im sure a 3g one would work (dont have any hard facts but i read that info some where).
    nice find on the clutch! I checked some things here at work and does in fact show that we sell the same clutch for the sonata 2.0 and the tiburon 2.7.
    I highly doubt a Mitsubishi diff would fit in a Hyundai trans.
    Yeah certain years the 2.4 and 2.7 engine share the same clutch for my na build i might run a stage one exedy which is good enough for my expected numbers.
    Actually there the same transmission internally if memory serves correct ill have to triple check but ive done research but i never documented anything so i cant remember 100%
    08-18-2004
    Charlotte, NC
    1,029
    the 2.4L I4 and 2.7L V6 use the same tranny just different bellhousing, so use a LSD for the Tiburon 2.7.
    1994 GS FYI
    DSM/CSM Manuals
    Thanks for the info! ill defiantly do more research to be 100%
  19. #39
    possibly wrong thread as this question is 6g7X related;
    would any of the hyundai v6 gearboxes bolt upto a 6g7x?? say the manua box from a tiburon 2.7L v6? it uses the delta v6, and from pictures it looks to share the same bell housing bolt pattern as a 6g7x
  20. #40
    ^^^pics of said bell housing?
