Thread: In car light problem
Showing results 1 to 5 of 5
    So after I've bought this 1994 galant, I want to put this car back on the road.
    I'm trying to figure out all the problems that it has.
    I'm currently working on the interior of the car.
    I have problem with the guage cluster lights (the onces that turn on when i turn on the headlights lights)and the once that are in the dash such as the buttons.
    I've chequed all fuses, also I replace the dim control, but no luck.
    Can you guys help me out with this?what else do I have to chec?
    so yur cluster dont turn on
    All the lights in the dash that has to come on when you turn the headlighs on, doesn't come on.
    NEWBIE Acidrain620's Avatar
    02-20-2011
    where ever the navy puts me!
    33
    i am having the exact same problem on my 94 galant es. but when i start the car the check engine light, low oil light, open door light, ect work just not the speedo, tach, temp, and gas will not light up.
    When I first got the G, the entire Instrument Cluster wouldn't turn on and lucky for me I bought it an hour from home and it got dark as soon as I hit the road. Had to use my phone to check my speed and temp. Next day, I went nuts looking for fuses. I figured there's no way all the bulbs went on it, wrong!!! All the bulbs the lit the panel were burned out. So simply replaced them.
