it could be misaligned shifter/cables or 5th gear syncros are going
Try getting Symborski shifter base bushings and brass shifter cable bushings
The syncros are easy to change too. Its is the first gear set when you pop the rear cover of the tranny. I believe its a 36mm nut and they come out
