Thread: Swapping 4g64 for a 6g72..need advice =(
Showing results 1 to 19 of 19
    PrityG-lant03
    Im swapping a 4g64 engine for a 6g72 engine in my 03 galant..can anyone give me some questions i should ask the seller or recommend some places to get my engine from or tell me the things i should take in mind before i go through with this???plzzzzz...
    05-03-2007
    Socal/Central Coast
    3,803
    how much of this have you planned out? Do you know everything that needs to be swapped out? If you're dead set on going to a V6, might as well go to a 6G74 since its basically a direct drop in.
    when buying an engine, check:
    mileage
    for any leaks, weather coolant or oil
    visible carbon build up
    make sure timing belt never snapped
    obviously make sure that the engine was running before they pulled it from the car. If it was, they'll typically give it some kind of warranty. Before you go buying anything though, I want to make sure that you know exactly what you would be jumping into.
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Going from a 4g64 to a 6g72 also remember that you have to change the tranny bc the
    4g64 and 6g72 are diff trannies. Sub frams are diff so will need some modification done to it, and a whole lot of wireing. You ganna be spending some money here...unless thats not a problem for you.
    Advice: dont do it. Just buy a v6. It will be cheaper
    Make sure you sell the i4 first then it would be even cheaper. And you get to drive the day of purchase....
    blue8g
    Quote Originally Posted by G-spot View Post
    oh and they don't mean just the engine
    Sell your car and buy a V6 galant
    (just clarifying)
    01-08-2008
    Levittown NY
    2,786
    (just clarifying)
    QFT do not attempt to swap a v6 into your 4 cylinder it will cost the same as buying a v6 galant.
    12-02-2008
    1,263
    ^+1 on that
    blue8g
    Quote Originally Posted by 03-Galant-ES View Post
    and it will cost you all resale, it'll probably not be near as reliable, and you won't gain much if any power/and you'll lose alot of potential (although the 6g7x guys are doing it big lately)
    PrityG-lant03
    So whats the catch with the 6g74 swap?how much will it cost and what mods will i have to do?
    blue8g
    Quote Originally Posted by PrityG-lant03 View Post
    Dude you have a 4 cylinder. Don't bother with either.
    why not? all he has to do is swap out the sub frames and a little wiring....
    but since your 4 cylinder, your best bet is fi, with a evo 8 head...
    blue8g
    Quote Originally Posted by galantman03 View Post
    exactly that reason. Although Evo head isn't necessary
    no its not but its the route i'm taking
    PrityG-lant03
    Dont want to sound dumb on anything but what is an "f".i
    Forced induction.
    I expected the Rocky Mountains to be a little rockier than this.
    PrityG-lant03
    Nos??
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by Stepsascend View Post
    Forced induction.
    Aka "Turbo"
    @OP if your a 4 cyl. your best options are:
    1) Build your engine and go Turbo
    2) evo or sonata/optima head swap + Turbo
    3) Complete evo engine swap + Turbo
    And to take full advantage of this options you would need to do a 5 spd swap.
    SEARCH there's so much threads about this, do Your home work.
    4g64T 5spd
    why not? all he has to do is swap out the sub frames.
    NOT true.
    Cali: Sig 3/28/2011
