Thread: what gauge battery wire?
Showing results 1 to 9 of 9
    I was thinking of relocating the battery to the trunk and was wondering what gauge wire i should use?
    And where can i buy wire for cheap?
    00GalantX
    The thicker the better, 2 gauge to 4 gauge , Autozone or Kragens sells them for a nice price.
    if you can get your hands on awg 0..better..
    I'm using 4, but I plan on going with 0 sometime next year.
    go to advance and just get battery wire its huge and different from normal wiring i wouldnt use normal wiring for this as it tend to get warmer from what i hear. ive got 2 batteries in my trunk run with battery cable and no probs at all it was like 30$ for all the wire too.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
    large fmic w/ cx racing intercooler pipes
    wrx injectors @ 100psi fuel pressure
    http://www.knukonceptz.com/index.cfm
    this is where i get all my wire from. 5000+ strands of copper in the 0awg flex stuff. this isnt like all 0 gauge, you can make a knot in it with a diameter of 3 inches. its crazy flexible unlike any other 0 gauge ive ever used. i have 4 runs of it in my competition stereo truck and two runs of it in my g for the battery in the back. its all cheap too. def check it out.
    08-04-2003
    NY
    4,344
    I actually use 2 gauge welding wire. You can buy it from any welding supply store fairly cheap. I think its like $4.50 per foot of wire. Same like Kyle described, super super flexible
    99' Galant ES
    4G64/63T
    AEM EMS
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    ^^Thats what some car audio guys use welding wire (Although some say it isn't as flexible, you just need to let outside in the sun and it will get flexible):
    https://weldingsupply.securesites.co...:OR:terms::PA2
    4g64T 5spd
    i ordered a 0 gauge amp install kit last night. should work fine i think, but it was 55 bucks.
    it does come with a bunch of sweet looking connectors though. lol.
