Thread: Horsepower??
Showing results 1 to 7 of 7
    Galant_Down_the_Bayou
    Horsepower??
    How much horsepower does my 94 gs stock have??
    Base Number of Cylinders: 4
    Base Engine Size: 2.4 liters
    Base Engine Type: Inline 4 -1
    Horsepower: 160 hp
    Max Horsepower: 6000 rpm
    Torque: 160 ft-lbs.
    Max Torque: 4250 rpm
    Drive Type: FWD
    Turning Circle: 34.8 ft.
    yeah but i only have a 2.0 liter dohc 16 valve
    Are you sure its a 94 ??? The 2.0 liter 16 valve engines (4g63) were in the 93 and earlier galants, US models.
    San Antonio, Tex-Mex
    1,413
    <div class='quotetop'>QUOTE(flipz_ny79)</div><div class='quotemain'>Are you sure its a 94 ??? The 2.0 liter 16 valve engines (4g63) were in the 93 and earlier galants, US models.</div>
    Actually not all, he may have a GS model 7g which was a 2.4L DOHC.
    In that case, what Nyctrini posted for numbers is correct...
    If it were SOHC like mine, your pushing just over 140hp
    <-Check it out Maz
    My 7g
    he said 94 GS, so thats a 2.4L no matter what, just DOHC, the SOHC had 141hp
    Bronx NYC (reppin)
    3,489
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
